New Lifts 2015
#202
Posted 05 April 2015 - 06:38 AM
#203
Posted 05 April 2015 - 06:59 AM
-Doppelmayr six pack replacing the Summit 1 lift
-Summit 1 (Hall double with CTEC mods) relocated to become an upper mountain lift
-Summit 2 (Doppelmayr double) shortened lower mountain lift
Source: http://www.skisugar....wasnt-enough-2/
By my count Doppelmayr is building at least 15 lifts this summer - 2 gondolas, 5 high speed quads, 4 six packs, 3 quads and a T-Bar
Posted 08 April 2015 - 09:55 PM
#206
Posted 09 April 2015 - 06:18 AM
http://ski49n.com/news.php
Trail map: https://skimap.org/SkiAreas/view/195
This post has been edited by Conrad: 09 April 2015 - 06:26 AM
#207
Posted 09 April 2015 - 06:56 AM
Reading that press release it doesn't sound like either lift will be built this summer. 49N barely operated 50 days this winter.
Posted 09 April 2015 - 09:01 AM
Peter, on 09 April 2015 - 06:56 AM, said:
You're right, sorry to mislead everyone. According to their Facebook page, "infrastructure with local utility providers, water system development, snowmaking infrastructure, and hospitality yurts and restroom facilities in Sunrise Basin are expected to be completed this summer."
#209
Posted 10 April 2015 - 06:17 PM
http://www.durangote...ll-speed-ahead/
boardski, on 05 April 2015 - 06:38 AM, said:
Chair 4 is planned to be replaced with a FG triple, but I wouldn't be surprised if they wanted to replace that one with a new lift since it is used fairly heavily. The planned "Gelande lift" would leave from the overflow parking lot along US-550 just south of the main entrance, and primarily be just an access lift. The slopes leading down to that lot would likely be too steep to build anything less than a black diamond trail. Plus those eastern aspects above the Gelande lot usually only hold snow for a week or so after most storms. That said, the used Legends triple might fit the bill for an access lift perfectly.
#210
Posted 12 April 2015 - 05:04 PM
#211
Posted 13 April 2015 - 06:33 PM
http://www.newenglan...php?storyid=239
#212
Posted 14 April 2015 - 06:08 AM
At a private club, nothing is overkill.
#216
Posted 20 April 2015 - 06:11 PM
This post has been edited by boardski: 20 April 2015 - 06:14 PM
#218
Posted 20 April 2015 - 07:42 PM
Loveland Basin with Ptarmigan.jpg (166.44K)
I can only imagine the modifications that will have to be done to the existing #2 to end it at the mid-unload. I don't think they'll have to change anything below tower 12 (the tower that #2 crosses over #6 on). But the downhill line on tower #13 will have to be lowered to the same level as the uphill line, and the shack on the downhill side of the line at the mid-unload will have to be moved across to the uphill side of the lift line, not to mention those two half-towers built to create the mid-unload will have to be modified, probably into a single hold-down tower with sheaves on both sides, and possibly a new return station. I wonder why they even modified the reload area to have a mid-unload on #2 in addition to the mid-load back in 2012?
This post has been edited by DonaldMReif: 20 April 2015 - 07:52 PM
#219
Posted 21 April 2015 - 11:23 AM
liftmech, on 20 April 2015 - 06:43 PM, said:
I think this has been in the pipe since last year and they signed with LP quite awhile ago now..
Laurence Sterne
#220
Posted 21 April 2015 - 01:51 PM
Donald, more than likely the whole lift will be redesigned. The truncated lift 2 will be less than half the length of its predecessor and will have different tension, drive horsepower requirements, and tower loads.
