New Lift Construction Photos 2014
302 replies to this topic
#101 DonaldMReif
Posted 07 July 2014 - 02:05 PM
So, within a month of the Colorado SuperChair's original quad towers vanishing, the six pack's towers have been flown in:
https://www.facebook...10558663&type=1
While they have the same design terminals, and presumably will have the same design chairs, the Colorado SuperChair's towers have walkways alongside the sheave trains while the Kensho SuperChair does not. And the Colorado SuperChair is reusing the previous tower foundations.
And this from the Summit Daily (http://www.summitdai...do-breckenridge):
A K-MAX cargo delivery helicopter zoomed over Breckenridge Ski Resort Monday, July 7, heralding shorter lift lines for skiers and riders on Peak 8 starting this winter.
Starting at 8 a.m., the helicopter hauled in 20 towers for the resort’s new Colorado SuperChair.
The Colorado [Super]chair, the resort’s most-used lift, will be upgraded this summer from a quad express to a six-passenger express.
The resort was able to skip a step in the renovation after the foundation slabs under the lift’s old towers were tested and found to be safe and not in need of replacement.
“That was a huge win for the whole process,” said senior communications manager Kristen Petitt Stewart, because it reduced ground disturbance.
The new towers were placed right where the old ones stood. The next step is installing the loading and unloading terminals, which will be slightly smaller due to improved technology. Stewart said the bottom terminal will be moved about 5 feet up the hill.
Then comes placing the hull [haul] rope and the chairs and testing for safety. The lift is scheduled to open with the rest of the resort for the winter season Nov. 8.
This latest renovation represents a 30 percent increase in the lift’s capacity, Stewart said, and should help disperse skiers to the peaks around Peak 8.
The Colorado [Super]chair was installed in 1986 as a high-speed quad.
It was updated in 2002 from a chain-drive to a gear-drive system, and in 2012 its chairs were replaced. Those chairs will be used to upgrade the Beaver Run [Super]Chair this year.
Over the last 14 years, Stewart said, Breckenridge has upgraded and added several lifts.
In 1999, the resort replaced the world’s first high-speed quad, the Quicksilver [Super6] lift, at the base of Peak 9 (installed in 1961), with the first double-loading, six-passenger, high-speed lift.
Three years later, the resort also upgraded Lift 4 to the Peak 8 SuperConnect.
Stewart said the Independence SuperChair arrived in 2002, followed by the Imperial Express SuperChair in 2005, the Breck Connect Gondola in 2006 and the Kensho SuperChair/Zendo Chairs in 2013 with the Peak 6 expansion.
The resort constantly evaluates its chairlifts and does upgrades when needed, she said, especially with control systems and software.
This post has been edited by DonaldMReif: 08 July 2014 - 06:45 AM
#102 Backbowlsbilly
  • 259 Posts:
Posted 10 July 2014 - 08:03 PM
Was up in Breckenridge on Wednesday and got some pictures of the progress on the new Colorado Superchair, these are from the boneyard of parts from the old lift on lower Peak 7.
This post has been edited by Backbowlsbilly: 10 July 2014 - 08:04 PM
#103 Backbowlsbilly
  • 259 Posts:
Posted 10 July 2014 - 08:09 PM
These next ones are from the line of the new lift where the new towers are on the old foundations. Sorry about all of the small sizes.
This post has been edited by Backbowlsbilly: 10 July 2014 - 08:09 PM
#104 DonaldMReif
Posted 10 July 2014 - 09:59 PM
Based on the pictures, it looks like they will have a midline hold-down assembly where the original lift's tower 11 used to be.
The photo of the new bottom terminal foundation makes me think there's a 50-50 chance the Colorado SuperChair is going to be an anticlockwise lift, just like the original, since I only see the concrete base for the terminal, and no foundation for a lift shack, probably allowing them to, like the original, share an operator's room with the Rocky Mountain SuperChair. I noticed that they took the blue nameplates off the Rocky Mountain SuperChair's terminals in the pictures, suggesting that maybe that plate and the one at the Mercury SuperChair might be replaced.
Did you get a chance to do a count of how many towers the Colorado SuperChair has? Hopefully someone has inside access to the Leitner-Poma specifics about the lift design.
And it's more or less a given that the safety bars on the Colorado SuperChair will have maps, seeing as the quad had them.
This post has been edited by DonaldMReif: 11 July 2014 - 02:04 PM
#105 2milehi
  • 1,035 Posts:
Posted 11 July 2014 - 12:00 PM
View PostDonaldMReif, on 10 July 2014 - 09:59 PM, said:
...The photo of the new bottom terminal foundation seems to suggest the Colorado SuperChair is going to be an anticlockwise lift, just like the original...
How do you get this information from a picture? Please explain.
#106 skierdude9450
Posted 12 July 2014 - 05:29 PM
I was up the other day and hiked the line so I can answer a couple questions. There are 20 towers, which for the most part use the old tower foundations. The depression at the old tower 11 will be replaced by two combination assemblies. It will run counter-clockwise like the old lift based on a few of the catwalks which were longer on the right side. It looks like they plan to reuse the vault from the top terminal, although it's hard to tell for sure.
#107 DonaldMReif
Posted 12 July 2014 - 10:36 PM
Running the Colorado SuperChair counterclockwise makes sense so that it can still share a shack with the Rocky Mountain SuperChair. The photos Breckenridge had on their FB page show tower 14 will be a combination tower (and it's about where tower 15 of the original lift was). That's at least three combination towers. Any other combination assemblies?
#108 liftmech
Posted 14 July 2014 - 04:07 AM
You can share a shack and still have the lift rotate the other direction. Perhaps we should reserve claims like this until the lift is finished. I've already had to close another topic because of this.
#109 DonaldMReif
Posted 14 July 2014 - 06:56 AM
OK. Any progress updates on the lift at Taos?
#110 Peter
Posted 14 July 2014 - 05:24 PM
Panorama's new Doppelmayr Eco Quad
#111 Nate214
  • 266 Posts:
  • Interests:Skiing, snowbiking, mountain biking, camping, hiking, cars
Posted 14 July 2014 - 06:22 PM
Here are some photos of the concrete pour day on July 1st. The re-bar cages were flown in as well for upper half of the towers. They poured tower 12 and the return. Heard the plan was to pour the towers too but the helicopter was lapping too fast for them to be ready. So there will be another pour for the towers coming up this week or early next week. I will keep my ears open for more details. Haven't run into Tim Nicu for a while they're busy guys up there while we are getting lifts ready for the winter. I like the last picture with the K-Max and Wheeler Peak in the background highest Peak in New Mexico.
This post has been edited by Nate214: 14 July 2014 - 07:17 PM
#112 Emax
Posted 15 July 2014 - 05:07 AM
Brian Head's new chair 2 is in the air.
Attached File  ch2.jpg (67.17K)
#113 Peter
Posted 15 July 2014 - 08:14 AM
A couple more from Brian Head
#114 SkiDaBird
Posted 15 July 2014 - 08:16 PM
A couple of really nice pictures here guys. Great job.
#115 DonaldMReif
Posted 15 July 2014 - 09:16 PM
I imagine the Kachina Peak lift has an awfully steep climb from the photos. Probably a whole lot steeper than the Imperial lift.
#116 Nate214
  • 266 Posts:
Posted 16 July 2014 - 04:06 AM
1,100 vertical feet. Right now lift #1 is the steepest lift we have. We have plenty of steep sections in our lifts but lift 1 is consistently steep the whole lift. The Kachina peak will probably be just as steep or steeper. Lift 1 is 49% average grade not sure Kachina peak lift average grade.
#117 jwilliams
  • 3 Posts:
  • Interests:mountains, weather, engineering
Posted 17 July 2014 - 03:34 PM
Wolf Creek posted a few pictures of the Elma lift construction today on their Facebook and Picasa pages.
https://picasaweb.go...39/RecentPhotos
https://www.facebook...olfcreekskiarea
They have widened the line a bit and staged the towers in the meadow near where the bottom terminal will sit. The bottom terminal has been in this location since last summer after it was removed to make way for the Treasure Stoke lift.
#118 RibStaThiok
Posted 17 July 2014 - 04:39 PM
What is going in at Wolf Creek?
#119 boardski
Posted 17 July 2014 - 05:18 PM
Former Treasure triple chair (1983 CTEC removed last summer to be replaced by the current Doppelmayr HSQ) is being reinstalled to create a new lift called "Elma" It will originate adjacent to Alberta lift and terminate just above the end of the traverse trail to the main base. Other than the name making me think of an annoying Sesame Street character, I look forward to having the long traverse back from Alberta eliminated. I will simply take an extra run back there and ride the "new" lift to return to the base.
#120 jwilliams
  • 3 Posts:
Posted 17 July 2014 - 07:55 PM
The name "Elma" is interesting. I asked someone at the ticket window in March and they looked at me like I was an idiot. The only clue I could find about it was a picture of the avalanche dogs on Wolf Creek's ski-safety page.
http://wolfcreekski....-ski-patrol.php
I'm guessing "Rusty" will never have a lift named after him.
