High Speed 8-12 Pack?
52 replies to this topic
#41 snoloco
Posted 22 April 2014 - 11:03 AM
View Postliftmech, on 22 April 2014 - 04:09 AM, said:
I'm sure the terminal is 'geared' properly.
I am just saying that it has a much higher terminal speed than most detaches I have ridden.
#42 skistats
  • 7 Posts:
Posted 21 May 2014 - 09:14 PM
Agreed. MHX needs to be a six pack.
I'd also like to see the Daisy chair replaced with a HSQ, and re-aligned with the base near the bottom of the carpet, up next to 5 bowl, crossing over Cascade Express, up through the canyon to the middle of Boulevard run.
This would:
1) service and increase lower intermediate terrain, including lower half of Boulevard, Dental Foss, SCUD, and Beaver Tail.
2) be below the tree line and still operate during storm cycles.
3) provide a more direct access to Cascade.
4) provide another lift out of the base area, and make it easier to move from the north side of the resort to the south side.
#43 DonaldMReif
Posted 05 December 2014 - 08:10 AM
How wide would a twelve-pack chair be? You'd need very wide lift line right of ways, at least double or even triple that of a high speed six pack.
#44 brad82
  • 71 Posts:
Posted 05 December 2014 - 12:39 PM
View PostPhalanger, on 06 April 2014 - 01:27 AM, said:
Doppelmayr has 4,550 pph design using a angle loading, where the chairs and the people approach offline from each other. The weak point is unloading the chairs more than loading them. There are also 4,000 pph beginner 8 seaters now which averaged very low stops, when the snow on the exit ramp was kept at the right angle. Making it flatter made it worse.
https://www.youtube....h?v=HkgW0iQckfs
However some of the new gondolas are also really impressive, Solden has an 8 person Doppelmayr one which does 3,600 pph at 6m/s. These use the longer platforms for loading.
https://www.youtube....h?v=6Iwm7vhUuAU
Ridden Tommeuses many times, it was definitely needed. The original proposal was for a 8 person gondola to replace the twin double fixed chairs, but this was then changed to a 8 person chair. From what I can recall from the discussion on remontees mecaniques at the time, this was due to a proposal by Doppelmayr that the 8 person chair with the asymmetrical contour would be more efficient at loading than a gondola, and the main goal was to return guests to tignes as fast as possible at the end of the day. During the day the lift runs nowhere near capacity, but come 3:30-5pm there are very few gaps on the chair as its the only way back to get back to Tignes from that valley, unless you want to fight for a place on the ski bus. In the human cattle herd that is the 'queue', the angry russian oligarchs wives and the french make sure to push right into every available gate so empty seats are few and far between.
The vast majority of the stops were caused by people not clearing the unloading area and causing a pileup. For the flow of people at that hour from Tommeuses and the other 6 pack and gondola that share the same landing is quite compact.
The sheer amount of people that concentrate at that point at the end of the day is quite staggering due to the vastness of Espace Killy. Literally thousands of skiers descend on that one lift towards the end of the day. I think most north American resorts would struggle to meet the surge STGM experiences each day at that point.
#45 Snowy Ferries
  • 154 Posts:
  • Interests:Skilifts, Ferryboats, Skiing
Posted 31 March 2015 - 07:59 PM
Whistler could do with 8-pack replacements for Wizard and Solar. Those lifts can get very crowded from what I've seen.
#46 Bogong
  • 199 Posts:
  • Interests:Corrupting society, Australian ski history, Backcountry and resort skiing, mountaineering, extended hikes, making ski resorts viable summer destinations.
Posted 06 April 2015 - 06:39 PM
The 8-pack in Australia is at Perisher resort and serves a low intermediate run. Despite that things run fairly smoothly and there isn't the carnage you would expect.
Posted ImagePosted Image
#47 Aussierob
Posted 09 April 2015 - 09:52 PM
Yes we could.
#48 RibStaThiok
Posted 10 April 2015 - 11:08 AM
I can see 8-Packs working great for areas that cover intermediate-expert terrain but defenitly not for beginners. People need to know how to read and comprehend the signs that explain/show how to load and unload.
#49 Mike12164
  • 54 Posts:
Posted 18 August 2015 - 09:45 PM
Never understood the appeal of 8-pack chairs vs. gondolas, monocable gondolas have the same or higher capacity, are much more user friendly and can be used to transport foot passengers and cargo, even at maximum speed. The terminal and overall footprint is much smaller too, 8-10 passenger gondolas can be roughly the same width as a quad chairlift.
Also with such a wide carrier I could see wind being a huge problem.
#50 DonaldMReif
Posted 18 August 2015 - 09:50 PM
The width of a gondola line is more like that of a high speed six pack than a quad.
#51 SkiDaBird
Posted 18 August 2015 - 10:20 PM
I would assume that it would relate to skier convenience, not having to remove skis every ride up, and weight on the line.
#52 liftmech
Posted 20 August 2015 - 04:21 AM
Can be, but cabins are so much narrower that they can run on a quad line guage (and often do). I suspect you're referring to the big gondis at Vail.
#53 DonaldMReif
Posted 20 August 2015 - 03:09 PM
I was thinking more about Red Pine Gondola, actually.
