Lift Construction Photos 2013
246 replies to this topic
#221 floridaskier
Posted 14 January 2014 - 09:53 AM
 DonaldMReif, on 14 January 2014 - 06:23 AM, said:
It is now interesting comparing both of Wolf Creek's high speed quads given that they have different Doppelmayr designs: both have DT-104 grips, but the Raven Express has UNI-GS terminals and Garaventa chairs, while the Treasure Stoke Express has UNI-G terminals and EJ chairs. I'd go down to do a photo tour of the Treasure Stoke Express lift like I've done with the Mountaintop Express lift (http://www.skilifts....?showtopic=9726) or the Kensho SuperChair (http://www.skilifts....?showtopic=9746) if I didn't live in Denver.
The coil spring grip option seems to be the only remaining holdover from the CTEC merger. Other than the general layout of the towerheads, everything else is Doppelmayr these days, even for the old CTEC loyalists like Deer Valley, which has 4 Uni-GS lifts with Garaventa chairs, but installed a Uni-G with Doppelmayr EJ chairs (and coil spring grips) in 2012.
Beaver Creek is the only old CTEC customer that comes to mind that started using the Doppelmayr designs right away, starting with the Birds of Prey Express in 2003. What's the last lift to have the Uni-GS and Garaventa chairs?
#222 snoloco
Posted 14 January 2014 - 04:16 PM
Don't the fixed grip drive terminals still have some CTEC designs in them? This is the Lookout Mountain Triple at Whiteface which appears to have a Galaxy drive terminal, yet everything else is Doppelmayr. The return is also CTEC. This lift was built in summer of 2008 and opened in January 2009.
This post has been edited by snoloco: 14 January 2014 - 04:17 PM
#223 Peter
Posted 14 January 2014 - 04:32 PM
I believe both of these terminal designs have been discontinued since that lift was built. The CTEC lift shacks live on though
#224 snoloco
Posted 14 January 2014 - 04:39 PM
This is the Skyline Quad at Sugarloaf, ME. It appears to have a slightly different drive and return, although they still use similar aspects to the ones from the Whiteface, NY lift above.
The image insert isn't working for the picture of the return, so here is a link to it.
http://data:image/jp...IQgK0IQmp//2Q==
This post has been edited by snoloco: 14 January 2014 - 04:42 PM
#225 DonaldMReif
Posted 14 January 2014 - 06:24 PM
Let's get back on topic.......
#226 Peter
Posted 20 January 2014 - 05:17 PM
A couple new pictures from the Sea to Sky Gondola Facebook page. I would definitely check this out passing through on the way to Whistler.
#227 DonaldMReif
Posted 21 January 2014 - 11:12 PM
I guess the Sea to Sky Gondola is not for the faint of heart.
#228 snoloco
Posted 22 January 2014 - 04:40 AM
Or those afraid of heights.
#229 DonaldMReif
Posted 22 January 2014 - 07:44 AM
That was kind of what I meant. That gondola would probably give me a lot of reminders of what it was like when I went up the Jackson Hole tram in the summer of 2010. I mean, that was a tram and this is a gondola, but still....
#230 floridaskier
Posted 22 January 2014 - 07:51 AM
What's up at the top of the Sea to Sky Gondola, is that a restaurant up there?
#231 Peter
Posted 22 January 2014 - 08:02 AM
Sounds like it will be your typical scenic lift with a restaurant, gift shop and trails at the top. There is also a trail from the base to the top but no free ride down if you hike up.
#232 DonaldMReif
Posted 29 January 2014 - 08:06 AM
Cabin spacing on the Sea-to-Sky reminds me a bit of photos I have seen of Crystal Mountain's gondola.
#233 DonaldMReif
Posted 05 March 2014 - 06:57 AM
I mentioned that A-51 and Checkerboard at Keystone both received additional modifications from Doppelmayr in the form of new lifting frames on their towers.
This link has better pictures:
http://www.remontees...rtage-1615.html
The photos firmly establishes A-51 as being a frankenlift as it is a Lift Engineering double chairlift, with used Riblet bail-chairs, and Doppelmayr sheaves, upper bullwheel, and lifting frames.
#234 boardski
Posted 05 March 2014 - 07:25 PM
I am surprised they used the original Yan grips with those Riblet replacement carriers. Were the Riblet internal grips not compatible with the haul rope or was there another issue?
#235 2milehi
  • 1,035 Posts:
Posted 07 March 2014 - 02:00 PM
Those aren't Doppelmayr sheave on the towers and Joe Grumunger who came from LE designed the lifting frames.
#236 liftmech
Posted 08 March 2014 - 05:43 AM
Yan sheaves: http://www.skilifts....werstation2.jpg
Doppelmayr sheaves: http://www.skilifts....werstation4.jpg
#237 snoloco
Posted 12 May 2014 - 03:46 PM
The Sea to Sky Gondola is operating and open. They do ski touring on it which I didn't know they did. This video shows some of the trip up as well as the stations. It also confirms that the Sea to Sky Gondola is a bottom drive lift.
https://www.youtube....h?v=8ReU9p4bDCY
#238 martinnv
  • 3 Posts:
  • Interests:hiking, skiing
Posted 21 May 2014 - 03:00 PM
I hiked up the Sea to Sky gondola about a month ago, while it was still closed. I measured the vertical rise at about 845m (from 40m to 885m). Here are some pictures.
#239 Peter
Posted 21 May 2014 - 03:39 PM
Thanks for the pictures, Martin! :kewlpics:
#240 floridaskier
Posted 21 May 2014 - 06:53 PM
Great shots. Anyone know why it has European style towerheads?
