Keystone master plans
Posted 17 September 2012 - 07:09 PM
http://www.fs.usda.g...prdb5333697.pdf
This map illustrates what Keystone has proposed. Almost all of it sounds reasonably attractive:
1. Replacement of Argentine with a high speed quad turning near the top of Haywood to end at the top of Paymaster, with an additional trail to cut over to Mozart and Diamondback, allowing one-lift access from Mountain House to North Peak.
2. Upgrading Wayback to a high speed quad and increasing capacity on the Outback Express
3. Adding a high speed quad in Bergman Bowl and a triple in Erickson Bowl
4. A surface lift in the Outback to replace the snowcat shuttle
5. Cutting new trails between Wild Irishman and Paymaster.
I see the proposed Argentine replacement as benefiting since it would relieve traffic on the Peru Express and Montezuma Express lifts.
Posted 18 September 2012 - 07:02 PM
Posted 18 September 2012 - 07:14 PM
boardski, on 18 September 2012 - 07:02 PM, said:
I take Diamondback instead of Mozart to avoid the bottlenecks of Mozart where it merges with Prospector, the exit run from the North Peak blue runs. Of course, it would make more sense for the Argentine replacement to start at the bottom of existing Argentine, turn with a midway load at the bottom of the defunct St.'s John line, and run up St.'s John to the Summit House, allowing a one seat ride from Mountain House to Summit House, since the proposed alignment would mean that you would take either the Argentine Express or Peru Express, then ski down and take the Montezuma Express (or take a proposed learning lift that's probably a double or triple).
This post has been edited by DonaldMReif: 25 September 2012 - 02:19 PM
Posted 19 September 2012 - 04:03 AM
To me the biggest bang for the buck is "Bergman Express" along with the surface lift at the top of Outback.
With the new Gondola Mid Station, I figure skier traffic would have lightened up at the bottom of 'Zuma but I haven't seen those dynamics since the install of the new Gondola.
And no plans with West Ridge....
This post has been edited by 2milehi: 19 September 2012 - 04:05 AM
Posted 19 September 2012 - 01:42 PM
I think part of the reason why the mid-station on the gondola doesn't appear to relieve traffic from the east queue to the Montezuma Express is for a simple reason: skiers would be taking their skis off after every lap.
Right now, I've always started from the Mountain House base because fewer people park there and it's a shorter walk than it is to go through River Run Village or heaven forbid cross that large free parking lot that's so big you can make out a good portion of it from the very top of Dercum Mountain.
Since this means the Peru Express doesn't get as much traffic, I wonder if demand for Mountain House base will have to rise before Keystone builds the Argentine Express. They might cut the trails between Wild Irishman and Paymaster earlier, although I figure that these new trails will primarily be lapped with the Montezuma Express.
Posted 23 September 2012 - 03:34 PM
There are some positives here too. The 4 upper mountain lifts on the backside all sound great to with runs for all skiing abilities.
Posted 23 September 2012 - 07:13 PM
My sister hates Keystone for the bottleneck reason. She also broke her wrist on a Dercum Mountain run years ago.
They are upgrading Wayback to a high speed quad. That could benefit the traffic returning from the Outback, but might be more effective as a lift to lap runs on if a few more trails were cut in that area.
Keystone - North Peak Backside and Outback with New Lifts.jpg (171.7K)
This image demonstrates that there is plenty of space around Wayback that a new run pod could be constructed without needing to build more lifts.
I'd say that if the Argentine Express goes in, it will still primarily be used for access skiing. It might also render the Peru Express lift redundant, and I doubt it would do much to relieve traffic at the Montezuma Express.
This post has been edited by DonaldMReif: 23 September 2012 - 07:33 PM
Posted 24 September 2012 - 09:11 AM
DonaldMReif, on 23 September 2012 - 07:13 PM, said:
There is a reason trails have never been and never will be built there - That is all south facing and is bare often
Posted 24 September 2012 - 01:50 PM
trooper1556, on 24 September 2012 - 09:11 AM, said:
Well, it was just a thought. Forgot that for a moment. I was under the impression that chairlifts are most ideal if they serve the double purpose of lap lifts and also access lifts. I now remember that I've seen photos of barren areas under the lower Ruby Express lift.
That they're making use of that unused space between Wild Irishman and Paymaster will definitely be a good thing. Still, I think the things Keystone ought to do to make sure people flow properly throughout the mountain:
1. Consider constructing a relief lift from the bottom of the Mozart/Prospector runout to the top of Dercum Mountain and puts some relief on Ruby Express.
2. Find ways to move everyone off of Schoolmarm, especially at the end of the day.
3. Reopen Whistle Punk trail under the Peru Express.
4. There ought to be ideal facing slopes to cut trails in the space between Frenchman and Flying Dutchman. They might be short, and there could be some difficult with the Montezuma Express present, but it looks potential.
5. Not directly master plan related, but possibly reconfigure the Ruby Express line in a way that cuts down on stops and slows due to misloads.
Posted 26 September 2012 - 02:17 PM
What I think makes Mozart get so crowded is the fact that when you are coming off the Summit Express or the Montezuma Express, Mozart is the first thing you see as it is directly in front of you. Diamondback, on the other hand, requires skating towards the Ruby Express unload, then scooting under the lift (not as easy to notice), then going down through the Ranger learning area.
Posted 08 January 2015 - 07:45 AM
Posted 08 January 2015 - 01:41 PM
DonaldMReif, on 08 January 2015 - 07:45 AM, said:
How do you know this?
Posted 08 January 2015 - 04:59 PM
Yesterday I was on the Outback Express lift, which for all this time had had 19 towers and 100 chairs, just like the Santiago Express and Ruby Express. But then I had a sneaking suspicion that something was different about the lift, like say, the chairs were a bit closer spaced, as in, like, the same spacing that the Dercum Mountain lifts use (I think as built the Outback Express lift was designed with a slightly lower than normal uphill capacity, given its location of approximately three to four miles from the base area). Here's some proof of that:
TThat is a chair 124 on the right:
I have no way of confirming that these additional 24 chairs came from the Peru Express and Montezuma Express, although the fact that the combined number of chairs taken off both lifts last year is equivalent to the number of additional chairs that the Outback Express seemed to have received (in addition to the upper terminal being repainted with dark green to match the bottom terminal). I think that the relative spacing difference can be seen here:
April 2013:
January 2015:
As for the master plan, it was on either the Part 5 PDF or Part 6 that it proposed adding additional uphill capacity to the Outback Express. It could be nothing, however, and I could just be imagining things, but I don't think so.
This post has been edited by DonaldMReif: 09 January 2015 - 10:50 AM
Posted 09 January 2015 - 09:28 AM
Here is a tidbit for you: Just because a lift is built to move 2800 PPH doesn't mean operationally that it can sustain those numbers. The best way to operationally increase capacity of a lift is to reduce/eliminate slows and stops.
Posted 09 January 2015 - 11:14 AM
As for the rest of the master plan, the two proposals I kind of more desire than others would be upgrading Wayback to a high speed quad, and the proposed high speed quad to be installed in Bergman Bowl (I keep imagining that this proposed Bergman Express would theoretically provide terrain similar to the terrain that the Kensho SuperChair across the way on Peak 6 services).
This post has been edited by DonaldMReif: 09 January 2015 - 11:29 AM
Posted 09 January 2015 - 04:06 PM
#18
Posted 10 January 2015 - 12:34 AM
Backbowlsbilly, on 09 January 2015 - 04:06 PM, said:
I feel like Keystone wouldn't get the backlash from locals either the way Jackson must be this year or Snowbird did for Mineral. I still occasionally hear people complain about it and it's been 15 years.
#19
Posted 10 January 2015 - 03:58 PM
SkiDaBird, on 10 January 2015 - 12:34 AM, said:
I would think that too, especially since Keystone would add a new area of hike to terrain/cat skiing following the lift expansion into the bowls also as part of the master plan. My ski team coaches complained about Imperial but not on the scale of Jackson and Snowbird locals.
#20
Posted 10 January 2015 - 05:11 PM
Although I think they might want to add extra capacity to the Ruby Express lift, or find a way to cut down on stops and slows caused by mis-loads (like remove the gates at the loading area and convert the lift to inline loading, like Breck did to the Independence SuperChair in 2008 and the Peak 8 SuperConnect in 2013). since that's going to be the sole way back to Dercum Mountain from North Peak, the Outback, the Outback Bowls, Bergman Bowl, Erickson Bowl and Independence Bowl.
This post has been edited by DonaldMReif: 10 January 2015 - 08:56 PM
