The current standard (not code, please), requires safety interrupts developed by electronic means (currently, read PLC) be duplicated - or redundant.
Discounting input or output modules damaged by either poor system design or sloppy transient voltage suppression, has anyone out there experienced a real PLC fault? For the moment, let's not consider an Austrian manufacturer's programming slip-up - which was both understandable and unforgivable. I consider it a design mishap and not an equipment failure. People screw up now and then.
My own experience has been that -given an even chance - PLCs are by far the most reliable pieces of equipment in the entire control system. Yet we are currently required (perhaps pressured) to either duplicate the entire PLC hardware or (like ABB and Pilz) use a so-called "safety PLC" - which is essentially the same thing, only more expensive an unrealistically complicated to work with.
When you think about it from a control standpoint, a ski lift is a damned simple machine. I have to wonder (once again) if we're hunting jacalopes with atomic weapons. I say this while also admitting that I am involved in this open-ended (never-ending) technical pursuit. Maybe it's just the fascination with the "latest-and-greatest". If that's what it is, then maybe it's forgivable - but it's still unfortunate. But if it is in all technical seriousness, then sounder heads might say that the boys in power are overly engrossed with their private parts.
This post has been edited by Emax: 20 June 2012 - 06:45 PM
