"a Shrinking Heavenly"
#43
Posted 23 May 2004 - 08:45 PM
You can see the bottom of Galaxy and the whole length of the Stagecoach Express.
#47
Posted 24 May 2004 - 12:47 PM
CAski, on May 23 2004, 08:47 PM, said:
I'm not sure the line visible on the aerial was the lift line. I seem to remember it going up to where Galaxy starts (I could be wrong - it was a long time ago).
A web site (http://www.skistats....resort=Heavenly) says that the lift had the following stats (accuracy not confirmed):
1,600 Vert
5,300 Length
6250 Bot El.
7850 Top El.
Based on these stats, I mapped out the following line, which nearly fits these stats (1,575V, 5226L, 6260B, 7850T)
#48
Posted 24 May 2004 - 12:50 PM
#54
Posted 24 May 2004 - 09:06 PM
CAski, on May 24 2004, 03:31 PM, said:
The thin line could be a power line or buried pipeline (gas or water). I see that a lot in the mountains around PC...or it could be the lift line. I just don't remember that well.
Powdr
#55
Posted 24 May 2004 - 09:24 PM
floridaskier, on May 24 2004, 04:51 PM, said:
Floridaskier,
I used 3DEM & DLGV32 Pro (Global Mapper). Both are Freeware (search Google). It is somewhat involved and requires patience. Here is how it is done:
1) Get the DOQ and DEM from USGS, or other state site. 10 Meter scale works best.
2) Start with the DEM in DLGV32, then overlay the DOQ, using texture map. This will give you a good overhead, shaded relief map where you can draw in lifts and area boundaries.
3) Remove the DEM shaded relief and do a bitmap export of the DOQ only to a jpeg file, with vector lines included in the options. Caution: this can create extremely large and time consuming files.
4) Go to 3DEM and load the DEM.
5) Overlay the jpeg image w/lines and area boundaries.
6) Create a 3D image by setting the view area.
7) Export to bitmap.
I can give you more detail if need. It also works with DLGs (topo maps).
Below is a project I'm working on that I plan to present to the PC Planning Commission regarding a new development at PCMR.
#56
Posted 25 May 2004 - 07:01 PM
#58
Posted 26 May 2004 - 09:58 PM
This post has been edited by CAski: 26 May 2004 - 10:01 PM
#60
Posted 27 May 2004 - 04:02 PM
This post has been edited by CAski: 27 May 2004 - 07:07 PM
