Chair Parking
Posted 04 August 2010 - 06:28 PM
- -Poma may be the new Quad, and Doppelmayr may be the last single, but Yan will always be the superior in detachables.
If in doubt, don't fall and roll unless you're in a Von Roll.
Posted 04 August 2010 - 10:10 PM
Chairs parked for the summer on an outdoor rail connected to the bottom terminal:
White Pass Summer 05 003.jpg (1.26MB)
Entrance to an underground cabin parking facility:
Cabin parking in an enclosed, above ground building:
Chair parking in the terminal:
Posted 05 August 2010 - 02:57 PM
Posted 08 August 2010 - 04:07 PM
At this point, I'd like to close this forum post, and thanks again to all of those who helped teach me about chair parking!
-stmad12
This post has been edited by stmad12: 08 August 2010 - 04:07 PM
Posted 18 August 2010 - 05:40 PM
Posted 19 August 2010 - 08:54 AM
Posted 23 August 2010 - 03:32 PM
liftmech, on 19 August 2010 - 08:54 AM, said:
Interesting Concept. How Do Detachable fix the spacing issue if the conveyor system is hooked up together?
Posted 23 August 2010 - 03:55 PM
SkiLiftsRock, on 23 August 2010 - 03:32 PM, said:
Usually the return station has clutches and spraggs on the curve (contour) tire conveyor. The carrier can then be slowed or sped up as required to sort out the spacing.
Posted 23 August 2010 - 04:07 PM
mikest2, on 23 August 2010 - 03:55 PM, said:
Cool. Thanks.
Are there any other ways to do it, or is this the only way?
Posted 23 August 2010 - 04:27 PM
On Doppelmayr lifts (I'm unsure about L-P lifts) there are two spacing systems. The "Fine" spacing system which uses the computer to control the contour speed to make minor changes to spacing. The other system is called the "Rough" spacing system. This system utilizes electronic clutches to disengage 3 tires and "hold" a carrier until the proper spacing interval has been reached.
SuperRat mentioned some details in another topic:
http://www.skilifts....?showtopic=7965
Off topic, but...
Would anyone who works on Poma lifts (John?, Mike?, others?) be willing to explain the spacing systems in use?
Posted 04 September 2010 - 04:50 AM
Pre-1992-3-ish, spacing was done by the chain system. The cadencing chain had four sets of fingers spaced evenly along its length. The engineer who designed the lift determined the speed of the chain relative to the rope, which could vary depending upon your chair spacing. The chairs would come into the terminal, get picked up by the chain, brought around the contour, and placed into the acceleration tires for the trip back up. (the top station has a chain with fingers on every link, and it merely takes the chair around the contour). This was/is a pretty simple system as there's not much that can go wrong with it. Either the chairs are in the fingers and thus properly spaced, or they're not.
The next system Poma has is the computer-controlled tire-cadencing system. Basically, it works the same as the Doppelmayr system, where there is an electromagnetic clutch that is engaged by the computer to advance the chair. The way Poma sets their terminals up, the clutch is connected to the tires on one side of the terminal. When engaged, it runs the second half of the contour a bit faster than the first half. When disengaged, the slower pulley ratio on the other side of the terminal runs that half of the contour. If the chair is where it needs to be, the computer will turn the clutch on for half of the chair's trip through the spacing section, and off for the other half. The first years of this system the slow pulley was connected to the contour via a one-way clutch, now it's a second electromagnetic one.
Posted 04 September 2010 - 11:40 AM
Posted 04 September 2010 - 12:11 PM
Posted 04 September 2010 - 09:30 PM
mikest2, on 04 September 2010 - 12:11 PM, said:
Hi Mike,
Out of curiosity, how is the VFD-controlled section of the contour driven when running on evac (or aux if so equipped)? Disengage from the gearmotor and lift ops push carriers through that section?
Cheers,
-Ryan
Posted 09 September 2010 - 06:27 PM
