Last weekend I rode up the BreckConnect gondola at Breckenridge just for a fun summer ride. I'm curious about its mid-stations though (or all mid-stations in general)..... between each mid-station, is there a separate haul rope and bullwheel set, or is the haul rope fed through each mid-station and continuous for the whole length of the lift? My best guess would be that there's a different haul rope for each leg, but I could be wrong... and that's why I'm asking!
Lift mid-stations
Posted 03 August 2010 - 09:37 PM
Posted 03 August 2010 - 10:13 PM
That's a Good Question.
It can be either 1 hual rope or more then one.
Most of the time it's 1 haul rope.
II think BreckConnect might have 2 haul ropes? Not 100% sure since i have not seen a installation on this lift.
Posted 03 August 2010 - 10:23 PM
Posted 04 August 2010 - 10:54 AM
http://www.skilifts....dden/madden.htm
Posted 04 August 2010 - 04:30 PM
Skier123, on 04 August 2010 - 01:22 PM, said:
You are correct, the midstation houses both drives.
Posted 04 August 2010 - 05:20 PM
Skier, on 04 August 2010 - 04:30 PM, said:
Is there any pictures of this mid-load station? I've never herd of this before. Two drives in one terminal. Does skilifts.org have a page on this lift?
This post has been edited by SkiLiftsRock: 04 August 2010 - 06:14 PM
Posted 04 August 2010 - 05:56 PM
Kicking Horse, on 03 August 2010 - 10:13 PM, said:
Good forums deserve good questions, don't you think?
Skier, on 03 August 2010 - 10:23 PM, said:
Okay, that makes sense. If that's the case, though, then where is the drive? (or are there multiple?)
Posted 04 August 2010 - 08:35 PM
SkiLiftsRock, on 04 August 2010 - 05:20 PM, said:
Yep. Here's the link: http://www.skilifts....sx/collinsx.htm
Posted 04 August 2010 - 09:21 PM
It's really 2 drives in 2 terminals. It was even designed so that the 2 lifts can be separated in the future if Alta decides to do so.
Posted 05 August 2010 - 04:10 AM
Assuming you're still referring to the BreckConnect, the drive is at the top (peak 8) station.
Posted 05 August 2010 - 05:30 AM
Posted 05 August 2010 - 07:28 AM
In lift systems with two seperate loops, there are usually (if not always) two seperate drives, one per loop. However, both drives are usually housed in the mid-station, because it's more convinient (and I would imagine less expensive) to have both drives in one terminal. Some examples of lifts that have both drives in the mid-station terminal are Collins Express at Alta in Utah and Panorama Gondola at Mammoth Mountain in California. Skyeship Gondola at Killington in Vermont is an example of a two stage lift with the drives in seperate terminals. The drive for the first loop is in the mid-station terminal and the drive for the second loop is in the top terminal. All of these lifts can be found on this site.
This post has been edited by Skier123: 05 August 2010 - 07:36 AM
Posted 05 August 2010 - 10:08 AM
