Beginnings of ropeway technology
No replies to this topic
#1 Kelly
  • 3,106 Posts:
Posted 16 March 2010 - 02:47 PM
This rope hoist was used in construction projects from the Italian Renaissance period of 1430. In this time period a number of architects have documented construction practices with text and drawings.
This image shows:
-An endless rope system
-Enclosed gearing
-Drive spool that has numerous wraps of rope indicating the knowledge of friction and tension interaction
-Input coupling
-Rounded gear teeth on the output gear indicating a need to reduce friction,
-Rounded teeth from wear…beginnings of modern tooth profile
-Two guide rollers (sheaves) to properly direct the rope to and from the drive spool.
Attached File  1430-Hoist.jpg (98.4K)
