Derail fix
Started by nickzeke, Aug 26 2009 08:26 PM
11 replies to this topic
Posted 26 August 2009 - 08:26 PM
I've been browsing these forums for a while and I got to thinking, when a chair derails, how do you get it back on to the sheaves? My guess is with a lifting beam, you could just pull it up with some sort of jack. But what about a chair without a lifting beam, such as Quicksilver at Crystal Mt, as this chair derailed last year.
Posted 26 August 2009 - 08:45 PM
Well in that particular case I know there was a cat brought in to help.
crystal 2-10-08 008.jpg (2.73MB)
Posted 28 August 2009 - 08:27 AM
For our towers without built-in lifting frames we have portable (snicker!) bolt-on lifting frames. I laugh because they're heavy, awkward beasts. I was involved in a de-roping while doing summer line work on an old tower and we chose to drive a tele-handler to the tower and lift the rope rather than haul the portable frame out.
Posted 28 August 2009 - 06:56 PM
With a chain hoist. You can see everything needed in this pic... You wouldn't have the work chair on a derail though.
Posted 29 August 2009 - 05:33 PM
With the A-frame (finger-smasher) you use a hoist exactly as you would on a permanent lifting gantry. As you can see from Allan's photo there's a lot more rigging involved, and it takes a much longer time. I've used the frames at Crystal, and they're not too bad (relatively speaking, of course) to lift. They're still awkward to install, though, especially on those old Riblet towers.
Posted 30 August 2009 - 11:35 AM
Here's a better derail pic and rigging.
Posted 07 September 2009 - 08:14 AM
Here is a riblet picking frame. We call her TINA she is a B
Posted 10 September 2009 - 07:45 AM
I can't really tell how that one's attached to the tower. The one I've used has two sets of saddles to clamp on the towerhead framework-- one for each side since it's asymmetric. The lifting frame then bolts to tabs in teh saddle.
Posted 29 October 2009 - 12:37 PM
As far as I know, every lift that did not come with a lift frame built on it, came with a "portable" unit similar to the ones pictured, no matter what kind it is, it's a bitch to get up and set up. We just put up a reengineered Riblet from Superior Tramways and I built lifting frames for all the towers and welded them on as they went up. The Superior engineers didn't like that we didn't ask for their blessing first but if (when) it derails, I only need the come-along. For our Hall lift, we built one for a tower and bought one of the bolt-ons from Skytrans (great folks) and will probably trying to add one or two a year.
Practically Everything is Practical
