Kelly, on 12 August 2009 - 05:46 PM, said:
This is an example of a "resettable" derail switch.
Member SkiBachelor maintains the Glosary and I suspect that a change is coming soon.
The standard change recommended derail switches (none addressed before) in the early 70's.
Mid 1980 standards and the language morphed into the Rope Position Detector (RPD) and away from the derail switch wordage but is still used as a interchangeable word.
As viewed in the year 2009 their certainly could be many improvements made to this design…as viewed in 1973 it was much better than nothing and still appears on many grandfathered or none jurisdiction ropeways.
Actual contact body "A" is protected by sheave geometry.
Rope rides over catcher "if" it lands on catcher…sometimes deropements can be rather violent.
A – water-tight body for contacts that are opened by pivot arm (or plunger)
B – Adjustable bracket that is attached to pivot
C- Trip arm that attaches to bracket
D- Cable catcher – design prevents assembly from excessive rotation, or stop bracket or bolt prevents excessive rotation. Catcher design also is slightly outdated as the rope has a high possibility of jamming in-between the sheave and sheave support arm. A slight deflector tab (seen on all new lifts) prevents this from happening.
Hi Kelly,
Roger that on RPD vs. derail switch terminology interchangeability in the past. What caught my attention is that it appears a deropement will destroy the trip arm or will bend/break the pivot shaft where it enters the IEC switch body. Since the catcher doesn't appear to extend below the sheave support arm, I would expect the top of the rope to be roughly at the same height as the bottom of the sheave support arm after a deropement. It appears that rope position is outside the range of motion of the trip arm and may rip off or bend the trip arm.
Depending on the laterial positioning of the switch body (which isn't clear without a vertical photo looking up), I would imagine one of these two scenarios would occur during a deropement:
- If the trip arm hub is set back (toward the center of the tower) from the sheave support arm, which I'm fairly sure it is, then the trip arm will swing up and impact the sheave support arm, at which point the rope will bend the trip arm upward as it continues toward the rope catcher.
- If the trip arm hub extends beyond the sheave support arm, the same thing will occur but with the added posibility of the rope striking the hub. Trip arm would swing fully upward and the rope would bend the trip arm as it continues toward the rope catcher.
Possibly the angle the photo is taken at is deceiving and I'm misjudging the range of motion of the trip arm. At the moment I'm unable to picture how the rope can reach the catcher with the trip arm remaining within the range of rotation of the switch. If this is indeed a resettable design and the trip arm survives, then it would appear likely the angle or photo is playing tricks on my interpretation of the geometry.
-Ryan
This post has been edited by rniemi: 12 August 2009 - 07:16 PM
