chair to snow clearance standards
Posted 21 April 2009 - 06:05 PM
Adaptive skiing, on Apr 21 2009, 06:40 PM, said:
Is it common practice to post clearance height at loading platform? examples of resorts that do.
We use 500mm (20") from chair seat top to load and unload ramps. Our Doppelmayr E type quads and LP sixpack chairs have more clearance underneath the seat than our Poma boomerang quad. I assume you are hanging up on some of your hardware ?
Posted 21 April 2009 - 07:52 PM
mikest2, on Apr 21 2009, 07:05 PM, said:
You are correct. Do you know if it is common practice at major resorts to post clearance heights given varying snow conditions?
Posted 21 April 2009 - 08:04 PM
Adaptive skiing, on Apr 21 2009, 08:52 PM, said:
No..........Why would you ? Lifts are designed for Skiers and now Boarders, If you are having trouble with your limos, you should redesign them. No area is going to change their loads and unloads to accomodate a fractional percentage of passengers. Sit skis are a good example of adaptive gear that has been designed to work with existing lifts. We have had trouble with certain snowboard bindings getting crushed under the chair, that is the manufacturers problem because they did not warn the end user that they had to fold down the binding to provide clearance on certain lifts. We have had no problems with our Limos (which I assume you built). So...............Why the question ?
Posted 21 April 2009 - 08:18 PM
Posted 22 April 2009 - 03:56 AM
We know adaptive equipment manufacturers try to design around these codes but we have made off season adjustments to ramps to make the chair height work better for our adaptive instructors and students. We do it for them because we believe the adaptive teaching program is good for our ski area and as long as the height is within the parameters set down by the code it should work for all riders.
This post has been edited by SuperRat: 22 April 2009 - 04:04 AM
Posted 22 April 2009 - 05:10 AM
Posted 22 April 2009 - 05:42 AM
The ANSI standard only has a max unload seat height (22”, 560mm) none for load, just the sign posted above.
Posted 22 April 2009 - 05:45 AM
mikest2, on Apr 21 2009, 09:04 PM, said:
For your info
For the Record.Ansi Code requires that chair height be posted at "all" loading points. This means uphill and Downhill loading stations
Posted 22 April 2009 - 12:17 PM
LiftTech, on Apr 22 2009, 06:42 AM, said:
Just a small clarification. Sno-Limo is built to and beyond exacting industry standards for adaptive equipment. Issue is not with equipment but sharing info as to snow to seat clearances and info to lift user thereof. Height posting certainly seems to be widespread standard.
Posted 22 April 2009 - 02:03 PM
ANSI is not a code it's a standard, we all should be looking to this as a minimum to our requirements and we all should be doing whatever we need to do get anyone no matter what their abilities or challenges are on the hill, enough said.
Posted 22 April 2009 - 06:09 PM
You and I are in Canada, the Z98 does not require signage as to ramp height. I don't have a code at home, but if memory serves me it is the same as the ANSI Std. 18-22" We keep all ours right at 20", As far as signs go..............We can't get passengers to read the signs we are already required to post, I don't need any more. A wise old area owner once said we need one big sign when entering a resort that says "Please read the f**king signs"
We can't load toboggans on our Poma Boomerang Quad, as there isn't enough room under the seat in the load area (and Poma prohibits it in their manuals)
Posted 23 April 2009 - 08:15 AM
BigWhite ramps and platforms are indeed very well maintained. THX
Posted 10 May 2009 - 09:55 AM
Not like I can tell which lifts have foot passenger rides built in, for lifts like Quicksilver and the Colorado SuperChair, or the Keystone Summit Express, have flatter unload ramps than others that are not meant for foot transport.
