2milehi, on Mar 26 2009, 12:00 PM, said:
Haul Rope replacement frequency.
#21
Posted 26 March 2009 - 11:23 AM
#22
Posted 26 March 2009 - 01:09 PM
Just got back from skiing 21" of fresh powder (just so you guys don't think I just sit around and thinking about ropes all of the time (yuk-yuk)) (Oh my aching knees)
#24
Posted 27 March 2009 - 10:17 AM
moura39, on Mar 27 2009, 05:22 AM, said:
#26
Posted 27 March 2009 - 07:02 PM
#27
Posted 27 March 2009 - 07:07 PM
zeedotcom, on Mar 27 2009, 09:02 PM, said:
Avg Line speed?
#28
Posted 27 March 2009 - 07:40 PM
Keymech, on Mar 26 2009, 01:23 PM, said:
Thanks for chiming in. The Von Roll (old River Run Gondola) at Keystone had it's haul rope replaced in '89 and it had about 50,000 hours on it.
#29
Posted 28 March 2009 - 04:19 PM
Kicking Horse, on Mar 27 2009, 10:07 PM, said:
I believe that we currently run at about 350 fpm during the winter. However, this lift will also get some hours put on it during the summer. Speeds will be lower for foot traffic, but I'm not sure how many hours that amounts to. Total hours at this point I believe are actually approaching 30,000.
#30
Posted 19 June 2009 - 06:28 PM
Rope has done 27,000 kM so far. Divide by length of rope (8.8 kM), multiply by 6 Bullwheels = 18,409 cycles for one winter. We'll probably do half that again this summer, so three to five years rope life. Guess we'll be seeing Splicer back here sooner than we think.
#31
Posted 14 February 2010 - 07:47 PM
We consider haul rope replacement after two resplicing ie.
First Splice = At the time of replacement
First resplice = Due factor , Rope elongation or any other as rope deformation at splicing zone
Second Resplice = Due factor , Rope elongation or any other as rope deformation at splice zone.
We never do third resplice.
PLEASE COMMENT
#32
Posted 14 February 2010 - 10:44 PM
As mentioned in previous posts......no two ropes are the same (even in the same factory), every application is different including the amount of cycles placed on a cable and its loading. (50% vs. 100%) Only a periodic inspection with the measurement of the lay length and the diameter of the cable could reveal elongation and damage that can determine the life of that cable.
I have seen some cables spliced many times due to inproper handling, improper fabrication, shrinkage on the spool, crummy splicing technique, etc.
Also if the normal elongation length of a rope in its lifetime is more than four resplices due to a short carriage length X 4, how would your splice theory be correct?
My .02
#33
Posted 15 February 2010 - 07:56 AM
#35
Posted 20 February 2010 - 01:39 PM
Link: http://www.ushabreco.com/index.html
Usha Breco’s parent company is Usha Martin … an international wire and wire rope manufacturer. –
Link: http://www.ushamartin.com/index.htm
Manoj – I suspect you are relatively new to the industry and might just be repeating what information was given to you by your employers. For standards in other jurisdictions I would suggest reading ANSI and ISO documents for more information. I suspect some of your customers or Usha Martin probably have this information.
My personal experience and any scientific explanation for rope retirement would mirror what other industry members have been saying…retirement after 3 splices is plain silly. But perhaps your company uses a lower tensile strength steel and a ambiguous tension service factor and is concerned about approaching the minimum yield strength.
For more information you can go to the SORT – Subforum Rope – Topic - Wire Rope History…it has about 1000 pages of information that you might be interested in. If you could give a web link or post a PDF or attach an image of the “3 splice retirement standard” that your company mentions, the forum members would greatly appreciate your efforts.
Thanks,
Kelly
#36
Posted 21 February 2010 - 06:04 AM
25 years ago I was asked by my boss at the time to build something to eliminate the launch of a grip onto a tuck. This was on the big Von Roll gondola at SSV, which at the time had quite prominent bulges at each tuck. It was pretty easy to do & worked perfectly... allowing the rope to last through that season, and eliminated grip-profile trip faults. The disturbance to the spacing control was minimal (a few meters per). Most folks didn't even know it was there, but the paint on the tucks told us it worked.
Of course on a healthy young rope there is minimal diameter difference (tucks vs elsewhere), but it seems to me that launching grips onto tucks is simply causing unnecessary wear to the exterior rope strands (at the tucks).
Since then I have always wondered why this (no-launch onto tuck) isn't commonly done. Detecting the tucks is very easy, as is using a stow clutch to hold a carrier back.
Any comments?
2) galvanized bright ropes
What is the experience out there thus far? Are you maintaining these ropes differently from traditional ropes?
#37
Posted 21 February 2010 - 07:21 AM
#38
Posted 21 February 2010 - 08:27 AM
Splicer, on 21 February 2010 - 07:21 AM, said:
Additionally: 90% of the time a rope will be retired due to work hardening in the splice area. A 3 splice criteria for rope replacement is not practical, I have many ropes that I have respliced 3 even 4 times and are still in service. Tucks are relocated at the time of the splice to establish new tuck locations. Admittedly, at the 3rd or 4th splice time frame in a ropes life cycle, work hardening will begin to appear and an estimate of remaining rope life can be made. MR testing can detect if the wire brittleness is causing internal wire breaks in the tuck/splice area.
#39
Posted 21 February 2010 - 10:39 AM
LuvPow, on 27 March 2009 - 01:01 PM, said:
Nope, it was replaced 2 years ago, but the new cable was the wrong shape and was making the ride exceptionally rough so it was replaced again. It is now on the 3rd replacement.
