On doppelmayr DS grips, there is a small piece of metal that hangs down that is on the same moving part as the mobile jaw. Is this related? If it isn't in a certain position then it will hit the brittle bar and stop the lift? It can't be that simple.
I found this on the site:
Doppelmayr's Detachable grips:
No, there is no spring keeping the grip open. Rather, the linkage between the mobile jaw (the part that moves) and the spring guide rod has a slot in it that allows the linkage to sit in one of two positions. The bottom of the mobile jaw has a spur that is pushed up and back by a plastic track in the terminal, and that locks the grip in the 'open' position. When the grip moves around to the other side, the track does the same thing only this time it is to the 'closed' position.
If anyone has a picture and can show if what is being talked about here 'the spur under the mobilejaw' is that thing that hangs down under the grip?
How do pomas work for grip force testing?
This post has been edited by sseguin613: 10 March 2009 - 06:16 PM
