Some lifts can be tested by installing a torque wrench directly onto the high-speed shaft (others by attaching a dynomometer between the brake disc and a comealong or chain winch) and attempting to rotate the lift through whichever brake is being tested. If the brake holds to that certain value, it passes. Poma also has a 'slip value' on their lifts which is 120% of the normal test value (for example, the Flyer's brakes must hold at 261 kg on the dyno, and must slip at or before 313).
A photo of this month's brake test being performed.
