Explosives Missing From Winter Park Colorado
17 replies to this topic
#1 Kicking Horse
Posted 23 March 2004 - 08:09 PM
Explosives Stolen From Winter Park Resort
Sheriff, ATF Investigating Break-In
POSTED: 12:44 pm MST March 23, 2004
DENVER -- The Grand County Sheriff's Office and Federal Bureau of Alcohol, Tobacco, Firearms and Explosives are investigating the theft of explosives from the Winter Park Resort.
Monday, resort employees discovered that a facility used to store avalanche prevention equipment, including explosives, was broken into and some explosives were taken.
Winter Park did not reveal the amount or type of explosives taken.
The sheriff's office and ATF investigators are working to identify the person or people responsible for the theft and to recover the stolen explosives. They are also trying to determine when the crime may have occurred.
The ATF set up a hot line for information about the crime. Anyone with information is asked to call (888) 283-2662.
The Grand County Sheriff's Office also has a Crime Stoppers hot line set up at (970) 725-3226.
(from 7news in colorado)
The type of Explosiveses stolen was used for Blasting Snow
#2 jeffgladnick
  • 44 Posts:
Posted 25 March 2004 - 11:04 AM
Well i remember being at Aspen Highlands this year, and seeing a ski patroller emerge from one of two identical concrete "huts" which i could peer into.
The thing was filled from the floor to the ceiling with dynamite, clearly labeled. We had stopped to ask him directions, and when i commented that there was a "hell of a lot of dynamite in there" he kind of nervously smiled and said "uhhh, yeaaaahh... you're really not supposed to see that"
It had two big locks on it, but i suppose if someone was determined enough.....
#3 KZ
    Multipurpose Machine
  • 2,087 Posts:
Posted 25 March 2004 - 02:49 PM
Ive seen a few of those things at sierra
Zack
#4 floridaskier
Posted 25 March 2004 - 04:53 PM
When they want to blast for avalanches, do they plant the dynamite on the mountain and then set it off with a detonator, or do they launch it?
#5 edmontonguy
Posted 25 March 2004 - 05:06 PM
It all depends on where they want to blast. Mountains by highways are blasted through Guns which launch the charge high onto the mountain where access is difficult or imposible. For areas like Marmot Basin which has a long avalanche prone ridge i beleive they blast it using airborne charges as acssess is very difficult. Also i have seen snow "horns" used. these are fixed horn shaped devices which are located in high avalanche areas they use a Propane mixture to create a "note" which resonates disloding any loose snow.
#6 KZ
  • 2,087 Posts:
Posted 25 March 2004 - 05:47 PM
Also ski patrol will go with hand explosives, light them then throw them down the ridge below.
Zack
#7 liftmech
Posted 25 March 2004 - 06:07 PM
Typical avalanche control programmes include hand charges (12" sticks of dynamite), avalauncher rounds (dynamite-tipped projectiles propelled by a charge of compressed nitrogen; principle is known to millions of bored high-schoolers as a potato gun), ski-cutting (wherein a team of patrollers will zigzag across a slope while hopping on their skis), and the occasional milk jug full of ammonium nitrate (used more for the sound than the explosive power, but occasionally a whole bag will have a hand charge placed inside it as a detonator and the bag will be dropped somewhere).
Hand charges are tossed at the normal fracture or release zone in a slide area; usually these have been mapped out for years and have detailed accounts of how much H.E. to use in any given snow condition. Avalauncher rounds are used in similar situations as the highway department uses howitzer rounds, where you want no-one in the way of a possible release. Ski cutting happens if there's only a small amount of new snow and release probability is low; the hopping is a method of determining how stable the snowpack is. Ampho (ammonium nitrate) is used mostly in marine snowpacks when it's been dumping for days and the slide areas are quite loaded. I've seen 50-lb. bags of ampho dropped from helicopters because that was the only safe way to deliver them.
#8 edmontonguy
Posted 25 March 2004 - 06:31 PM
Driving along most mountian higways but the Icefeilds Parkway (running from banff to jasper down the spine of the rockies) especially small "turrets" can be seen from where Howitzer rounds are fired.
Before any rounds are set off is a sweep of the area required? And for projectiles is a warning needed and how is it delivered?
#9 ccslider
    ccslider
  • 186 Posts:
Posted 25 March 2004 - 06:57 PM
The "Horn" type device that burns propane is called Gas-Ex. You can see a good example of this along Carson Pass near Kirkwood. Fairly pricey capital installation cost but good for multiple uses in the same area.
Liftmech gave a good synopsis of different avi mitigations. Another one is the bombtram, where hand charges are ferried out to a starting zone by a mini-tramway (like a jig-back system) that can be powered by all sorts of means including a hand crank. Put extra long fuses and ferry the device to where you want it and bang - big airblast to give the snowpack a shake.
#10 liftmech
Posted 25 March 2004 - 07:04 PM
If there is to be any control work during operation the area will be closed. Usually control is done before operation, though. Any time after 7 AM (at Copper, anyway) patrol will announce when and where the work will take place over the radio: 'Fire in the hole, Union Bowl, next half-hour.' There is one face that runs side-by side with the ramp at the top of the Flyer (photo below); this will occasionally be done while operators are setting up, and patrol will also phone the top shack to warn them.
#11 Allan
Posted 25 March 2004 - 07:22 PM
We have a steep ridge about 50 feet above (and over the other side) from the top of the Paradise chair - more than once I've missed the fire in the hole warning, and only heard the big blast... scares the crap out of me every time!! We do all control work before public are allowed on the mountains - occasionaly, like liftmech said, the operators will be doing setup but that's it. All our bombs are hand thrown.
#12 edmontonguy
Posted 25 March 2004 - 07:28 PM
At Marmot i have heard blasting well into the afternoon especially during storms. its kind of scary skiing cause all you hear is BANG and it echoing off the Basin
#13 KZ
  • 2,087 Posts:
Posted 25 March 2004 - 07:29 PM
Some of my brothers friends built a giant potato gun. I have yet to try it, but when i do i will try to get pictures
At squaw, control work will go as long as it needs to. They will usually do the front sections (KT-22, Headwall and Siberia) first, then they will move over to granite chief, and silverado will usually open a day or 2 later.
As far as the system on carson pass, it is very interesting. THat road is sure built on a steep slope. They have signs that say "no stopping, yelling or getting out of your car" Well you guessed it, 2 years ago, a slide occured up the road on the way to the lake, so traffic was really backed up becasue everyone going to heavenly was going to kirkwood. Well we were probably stopped in the "Avalance Area" for a good 45 minutes to an hour, all this after a nice big snowstorm. People were out of their cars yelling and playing with snowballs throwing them at the hill and eachother. Quite an interesting experience, including the most crowded day ive ever experieced on the slopes (crazy wind, 45 minute lift lines and people).
Zack
#14 iceberg210
  • 1,064 Posts:
Posted 25 March 2004 - 07:50 PM
Here in Utah at least in the Cottonwood Canyons guns are used more often than hnd charges it seems. This is because the pplaces you would need to get to are in avalanche danger themselves.
#15 floridaskier
Posted 27 March 2004 - 12:53 PM
Are there any avalanches in the area, or do they have it pretty well under control? Because if there was one, and it blocked the road, there's no way to get in or out of there
#16 CAski
  • 363 Posts:
Posted 27 March 2004 - 10:24 PM
Skiing on the backside of Northstar during a powder day, while it was still snowing, I kept hearing this roaring like thunder, but I couldn't make out what it was exactly or where it was coming from. Hearing it many times through the day, my friend and I came to the conclusion that it was simply thunder (although we both agreed that thunder should not occur in the conditions at hand). The next day, we were told that it was avalanche control at Squaw and Alpine Meadows. Appearently those things are incredibly loud. :blink:
#17 floridaskier
Posted 28 March 2004 - 05:26 PM
Sometimes in the morning at DV you can hear avalanche guns go off. However, it might be in Little Cottonwood Canyon, because they sound really far off
#18 KZ
  • 2,087 Posts:
Posted 28 March 2004 - 07:31 PM
At squaw last spring on a fluke powder day, while riding up granite chief, they were still blasting the other side you hike to, so one went off right as i was unloading the chair. It was a smaller one, but it is still quite suprising when you arent expecting it.
Zack
