Power consumption
4 replies to this topic
#1 gatsu
  • 1 Posts:
Posted 06 December 2008 - 08:36 AM
Hello guys, I'm new here. I don't know much about ski lifts and I'd like to know some kind of general estimate on power consumption (in kW).
I understand that it probably is very dependent on factors such as type of lift, cable length and incline so..
Let's assume 2 seat chair lift, 200 m transport distance (ie around 400m cable length, right?) and 0 incline, ie horizontal movement only.
Is it possible to from this come up with some kind of approximate on the power consumption? It does not have to be very exact, just a guideline.
Thank you!
#2 2milehi
  • 1,027 Posts:
Posted 06 December 2008 - 01:07 PM
Thank you!
Too many variables, the answer would only be a SWAG.
#3 Emax
Posted 06 December 2008 - 02:14 PM
If you are able to convert your many variables into required horsepower, then the electrical load will be about 1kW per horsepower. (746 Watt/hp is the theoretical equivalent - 1000 Watt/hp is closer to reality)
#4 Peter
Posted 06 December 2008 - 03:15 PM
Virtually all the lifts of that length in the lift installation surveys have 75 hp.
#5 Aussierob
Posted 06 December 2008 - 09:31 PM
I'm thinking less than that. For a lift with no vertical rise I would think 50HP (37kW) would be lots.
