Leitner-Poma - Doppelmayr Ctec Lift Ops Questions
Posted 02 November 2008 - 03:56 PM
1.What are the main differences that a lift operator sees on the Leitner-Poma lifts and Doppelmayr Ctec lifts?
2.From a Lift Tech point of view Which is easier to work on?
3. Any tips for lift operators on either Doppelmayr Ctec or Leitner-Poma lifts to make it easier for them?
Thanks guys. Let's keep it clean in here.
Posted 02 November 2008 - 04:31 PM
A little different format on the versa views, dopp/c-tech uses a remote station ready signal to enable the start.. some use cutler hammer buttons others use allan bradly , some use square d
Ford? Chevy ? Toyota ? Honda? all good product brands different flavors. Just depends on what you are used to.
Follow directions and area/ manufacturer procedures.
Posted 06 November 2008 - 06:18 AM
My operator tip of the day is maintain your ramp. A little TLC frequently will make your day go better and you will be in the bar quicker if you don't have to spend an hour at the end of the day fixing it.
Posted 10 November 2008 - 10:01 AM
The more expirienced ops like myself were also trained to run the evac engines and as far as I could tell the Poma system has one of the fastest aux/ evac engine changeover systems, although the only other kinds I had expirience with were Heron-Poma, Yan and Hall. I thought the pedestal controls and and main control panels were very user friendly though the newbie op would more than not press the E-Stop instead of the service stop. I look at the Dopp panels at sugarbush and the dial thing just looks weird.
I don't know if that helps you or not *shrug*
Posted 01 August 2009 - 03:22 PM
there is no sense in moving staff thru lifts and expecting them to understand the nuances of each lift, without letting them spend time at them.
controls, sounds, feel, all are important in being able to operate the lift efficiently and be able to pick up problems in the early stages.
a feel of ownership of a lift on the Ops dept side instills a pride in product and healthy competition between lifts and lift areas
Posted 01 August 2009 - 09:31 PM
I agree with you 100%.
Posted 04 August 2009 - 07:32 PM
Posted 04 August 2009 - 07:34 PM
2milehi, on 04 August 2009 - 07:32 PM, said:
Hmm If i'm not mistaken the tramway code states that the start bell shall ring for a min of 2 secs BEFORE the lift starts...
Correct me if i'm wrong please.
Posted 05 August 2009 - 06:07 AM
Hope this helps.
#18
Posted 19 August 2009 - 07:05 PM
Aussierob, on 06 November 2008 - 06:18 AM, said:
Is the "ready system" when the lift attendants at each station have to push the "ring" button before they start the lift? If so, I think Garaventa CTEC used that system before they merged with Dopplemayr.
#20
Posted 19 August 2009 - 07:20 PM
Once I have clear from all stations I fire her up.
