Evacuation Motors
Posted 07 October 2008 - 08:16 AM
Posted 07 October 2008 - 08:34 AM
skierdude9450, on Oct 7 2008, 09:16 AM, said:
On our big lifts we run a main drive electric, an auxiliary (80-100%) diesel drive, and an evacuation diesel drive(1.5 m/s).This way if the power goes out or the main drive fails, we can still operate as we still have an evacuation drive. Some areas will run on their aux diesel at peak times to reduce their electrical utility peak demand charges.
Posted 07 October 2008 - 08:52 AM
In Europe, many resorts use diesel powered generators ("gen sets") to generate their own electricity in the event of a power outage. They may have a small diesel evacuation engine to run the lift at @1.5m/s in the event of an electric drive failure.
In North America, lifts are required to have at least power units (ANSI 3.1.2.1) one of which is an Auxiliary Power Unit (APU) with an independent power source - that means you can't have a second electric motor as a backup to you primary electric motor.
What you generally see in N.A. is:
Primary mover = electric motor (there are lifts that utilize diesel prime movers)
APU - this can be either full use (80-100% speed) and utilize the same controls as the primary mover; OR an evacuation APU which only is required to run the lift at 100FPM (.51 m/s) These units are generally diesel engines, while some older or smaller fixed grips utilized gasoline engines.
Hope this helps...
P.S. Ya got in there ahead of me Mike!!
This post has been edited by Lift Dinosaur: 07 October 2008 - 09:18 AM
Posted 07 October 2008 - 10:23 AM
skierdude9450, on Oct 7 2008, 07:16 AM, said:
I don't know if the new system will have an evac motor but the former River Run Gondola had the main electric drive, Diesel APU, and a Hydrostatic evac motor that acted directly on the teeth on the bullwheel so that it was not reliant on the gearbox or the rest of the drive line to provide power. I do not know the speed it would run it at but I would assume that it would be around the 1.5m/s mark.
The majority of aerial lifts, and some surface, in colorado, at least that I am familiar with, have a near full service APU more for the convenience of guests than anything, so that if power is lost the resort can continue to operate at close to full capacity.
This post has been edited by poloxskier: 07 October 2008 - 10:26 AM
Posted 07 October 2008 - 02:26 PM
poloxskier, on Oct 7 2008, 01:23 PM, said:
I believe Aspen has something similar.
On the American Eagle at Copper, the diesel engine couples to the gearbox. On the Eagle Bahn at Vail, there are two diesel generators and two electric drive motors. I do not believe there is another engine that couples to the gearbox. Anybody know if that lift has another evac system? Maybe hydro?
Posted 07 October 2008 - 04:13 PM
poloxskier, on Oct 7 2008, 12:23 PM, said:
This is known as a Tertiary or "third" drive system. It is often a hydrostatic motor with a pinon gear that runs on a ring gear inside the bullwheel. For this to work, you need a fast disconnect coupling to disengage the bullwheel from the gearbox.
I'll look for some photos...
P.S Post 3 should have said "have at least TWO power units..."
Posted 07 October 2008 - 04:41 PM
Posted 07 October 2008 - 05:28 PM
skierdude9450, on Oct 7 2008, 06:37 PM, said:
Correct. Most are diesel engines that are shaft coupled thru the gearbox to run the lift.
For some reason, even though diesel fuel is STILL cheaper here than in Europe, N.A. Resorts haven't grasped the concept of still providing "full service" during a power outage. You can ride the lifts, but you can buy food or drink because the credit card readers and cash registers aren't working (sept for the Mom and Pop areas where it doesn't require electricity to open the Cigar Box!!)
Posted 07 October 2008 - 07:50 PM
aug, on Oct 7 2008, 05:41 PM, said:
Aug,
Was this the APU arrangement before the lift was modified?
Posted 07 October 2008 - 07:58 PM
yes Yan original Equipment... vertical drive electric motors to a planetary hollowshaft gearbox. The aux. elec motor sits adjacent to the main and is coupled with a fibre cog belt to the input shaft of the gearbox.
Posted 07 October 2008 - 08:17 PM
Kicking Horse, on Oct 7 2008, 09:12 PM, said:
Then they also had a 3rd motor that I dont know anything about.
The third one most likely is the hydraulic aux.power unit.( for evac only). The big diesel is the Standby engine( normaly ok to run and load with)
Posted 08 October 2008 - 06:15 AM
aug, on Oct 7 2008, 08:58 PM, said:
Yea, the Yans I was around had a Aux. diesal that drove a hydrastatic motor that drove the cog belt. The belt was very touchy as far as alignment. Also, we were not allowed in the motor room while this setup was running due to an incident (where?) to a maintenance person getting hurt when the hydrastatic motor blew up on him. Hard to watch the belt and everything else from outside the motor room. The worst part was having the aux. motor adjacent to the operator shack. Hard to get a nap in while the motor was blasting at 2000 rpm
Posted 09 October 2008 - 07:24 AM
SuperRat, on Oct 8 2008, 12:15 AM, said:
We don't, but it would be possible to do. Not sure of the technicalities of the lift codes though. They may specfically require the evac drive to be part of the lift. As for the 24v system, the alternator on the diesel engine provides the 24v at the drive and an alternator driven off the lift provides power at the return. If you were using the snowcat method, you would need a 24v supply if the batteries in the lift didn't have enough power to run the lift until the line was cleared.
Posted 09 October 2008 - 01:08 PM
Aussierob, on Oct 9 2008, 11:24 AM, said:
I worked briefly at an area with a CTEC detachable that had a tertiary drive that was powered by the hydraulic pump of a cat. There was even a special hole in the terminal enclosure for routing the hydraulic lines. I never got the chance to see the system in operation. There was also a question about whether any of the area groomers were wired to be connected to the lift's controls which was required by the local tram board.
#19
Posted 16 October 2008 - 09:00 AM
SuperRat, on Oct 8 2008, 03:15 AM, said:
At Deer Valley, a number of the older Yan's were set up with a snowcat drive tertiary which we did test occasionally. I believe Northside, a 1993 CTEC detach, also had a snowcat tertiary. As far as electrical connections go, hopefully the lift's control system batteries would be enough to run the safeties for as long as it took to run the people off. The only other required connection would be two wires to close the cat's fuel solenoid when a stop is issued. That's all that runs to most non-fulltime APU's.
#20
Posted 16 October 2008 - 03:24 PM
