What is this.
Started by Splicer, Jul 05 2008 12:30 PM
27 replies to this topic
Posted 05 July 2008 - 08:24 PM
Okay, here's the scoop. This is a hydrostatic spooler. It clamps on the 56 mm full locked coil track cable then pulls about 1 meter of track cable off of the reel, then it releases, rolls back then re-clamps and pulls off another 1 meter of track cable. It is located on the Blackcomb side of the Peak to Peak 3S installation. After about 1 meter is pulled off of the reel, then 1 meter of "sand line" is spooled up on the Whistler side. It's works out to 1 meter every 12 seconds. so the length needed across the canyon is 4600 meters. There are are 4 tack ropes, one is now pulled and as of July 4th, the second is on the way.
