Compression Assembly
62 replies to this topic
#1 coskibum
  • 596 Posts:
  • Interests:Skiing, Running, Mountain Biking, Baseball, Hiking, ski history, and Chairlifts.
Posted 06 March 2004 - 10:30 PM
Check out this compression assembly on the birds of prey lift at BC...I have never seen one that was not symmetrical like this before!
  • Attached File  2.jpg (41.1K)
#2 liftmech
Posted 07 March 2004 - 04:29 AM
Storm Peak at Steamboat has one like that. I don't understand the need, since typically anything bigger than a four-sheave assembly has a definite positive load on it. But Doppelmayr does things differently...
#3 Dr Frankenstein
    C.S.I.A. Level 1
  • 436 Posts:
  • Interests:Computers, skiing
Posted 08 March 2004 - 05:37 PM
Other 2/6 compression assemblies:
The Express (Mt. Avila)
The Quad (Belle-Neige)
#4 Allan
  • 2,733 Posts:
Posted 09 March 2004 - 08:04 PM
This ones pretty funny too (from our T-BAR)
#5 edmontonguy
    Edmontonguy
  • 927 Posts:
Posted 09 March 2004 - 08:15 PM
a neat one i've seen was similar to that. It is an 8 sheave assembly with 4 sheaves supporting and 4 sheaves compressing but the sheaves are all in a line. Also a Doppelmayr
This post has been edited by edmontonguy: 09 March 2004 - 08:16 PM
#6 liftmech
Posted 09 March 2004 - 08:17 PM
...and from H-lift; A-lift and Blackjack each have at least one like this as well.
#7 Allan
  • 2,733 Posts:
I may have an explanation... We had to put two support sheaves on tower 4 on Red which most definitely has a negative load on it - the reasoning behind it was depending on how the bottom operator would load the chair, it would set up a line bounce between towers three and four that would cause the haul rope to hop right off the assembly into the rope catcher.
#8 liftmech
Posted 09 March 2004 - 08:20 PM
That's a pretty common assembly on Doppelmayrs; you'll also see them in place of the above Yan assemblies on many lifts that Doppelmayr retrofitted. Doppelmayr and Riblet were alike in that they both used combo assemblies like that even if the load was positive enough to keep the rope on the sheaves without additional help.
#9 edmontonguy
    Edmontonguy
  • 927 Posts:
Posted 09 March 2004 - 08:30 PM
The Eagle Ridge quad @ marmot has combination assemblies on almost ever tower. I believe this is because the lift line changes angle so much and is rather steep.
#10 Allan
  • 2,733 Posts:
Posted 09 March 2004 - 08:32 PM
Is this the type of assembly you mean?
#11 liftmech
Posted 09 March 2004 - 08:34 PM
Is that a Poma assembly? It sure looks like one.
#12 Allan
  • 2,733 Posts:
Posted 09 March 2004 - 08:41 PM
*points at the logo at the bottom of the pic...* Yup :P
#13 SkiBachelor
Posted 09 March 2004 - 08:50 PM
Kind of off topic but kind of on topic too, but how are Poma's new sheave trains greaseless? I mean it seems that they would get hot and burn up.
#14 liftmech
Posted 09 March 2004 - 08:54 PM
I need new glasses B)
As for Poma's new sheaves, etc being greaseless- what that means is that we (the mechanics) don't have to grease them. There is still grease inside the bearing, but it's a 'sealed' bearing, meaning that the grease supposedly doesn't leak out. The assembly bushings are rubber and do not require grease. They're kind of cool in that when you lift the rope off the sheaves, the assemblies don't articulate and smash your fingers :stretcher:
#15 Dawson
  • 24 Posts:
Posted 10 March 2004 - 12:58 PM
Interesting that the Poma sheave train picture shows a cable catcher both on the upper and lower assembly. Is that standard for towers with compression sheaves?
#16 Allan
  • 2,733 Posts:
Posted 10 March 2004 - 01:52 PM
It is standard - they're on our compression assemblies too... you just never know which way the rope's gonna go :)
#17 KZ
    Multipurpose Machine
  • 2,087 Posts:
Posted 10 March 2004 - 05:53 PM
On Upper Panorama they have 2 sets of those on a tower, so a total of 16 Combination. I will check if i have a picture.
Zack
#18 floridaskier
Posted 14 March 2004 - 05:32 AM
DV's Jordanelle Gondola has one tower with compression sheaves like the ones on the Birds of prey lift
#19 Dr Frankenstein
    C.S.I.A. Level 1
  • 436 Posts:
Posted 14 March 2004 - 04:06 PM
The Tremblant gondola and the Flying Mile Express have a 8-8 compression too.
This post has been edited by Dr Frankenstein: 14 March 2004 - 04:10 PM
#20 Dr Frankenstein
    C.S.I.A. Level 1
  • 436 Posts:
Posted 14 March 2004 - 04:10 PM
White quad, Mt. Habitant:
