At St. Christoph the moving carpet is covered for your comfort.
Down in St. Anton is the new gondola. It loads backwards then is flipped up on a huge conveyor to the line.
Axamer Lizum uses a funicular, which snakes up the mountain at almost an even grade ... and the cars are built to that grade. Two trains start from either end on a single track and pass each other in the exact middle. You can see that middle track here if you look closely.
Scheffau, in the SkiWelt area, has a double quad.
Kitzbuhel has an amazing new gondola with room for 30. The modernity also extends to the gondola station.
Nearby Jochberg, meanwhile, has not changed in decades.
Going also has a funnicular.
And an old bubble double.
