Help plz
Posted 16 January 2008 - 04:28 PM
3.1.1.2 Capacity and speed
The designer shall specify the maximum and minimum design
capacities and carrier spacing in each direction and the design
loading conditions under which the aerial lift may be operated.
The maximum rope speed shall be that specified by the designer
and established as functional by testing and operational performance.
Maximum relative carrier loading speed for detachable chair lifts.
1-4 passenger chair | 6 passenger chair | 8 passenger chair
Skiers - 450fpm(2.3 m/s) | 425fpm(2.2 m/s) | 400fpm (2.0 m/s)
Foot passengers 250fpm(1.3 m/s) | 225fpm(1.1 m/s) | 200fpm (1.0 m/s)
Also, on lifts that travel over 600 fpm, RPD's must be installed to monitor the position of the rope.
Posted 16 January 2008 - 08:53 PM
Superchairliftfan, on Jan 16 2008, 08:21 PM, said:
And what would your deceleration curve look like ?
Posted 16 January 2008 - 09:11 PM
Edit: Nevermind, I see that is for detachable chairlifts only. What are the max speeds for fixed grips?
This post has been edited by Skier: 16 January 2008 - 09:12 PM
Posted 16 January 2008 - 11:38 PM
FG lift ANSI standards rope speeds are:
Single: 600fpm
Double: 550fpm
Triple: 500fpm
Quad: 450fpm
Posted 17 January 2008 - 07:04 AM
Superchairliftfan, on Jan 17 2008, 07:37 AM, said:
metric conversion site: http://www.worldwide....com/metcal.htm
Posted 17 January 2008 - 11:35 AM
when we are having issues with our rope monitoring and have to run a detatch at 600 fpm i can not believe the complaints from the guests that the chair is running soooo sloooww. what is the hurry . is there some kind of race going on that i am not aware of??? I am just glad that I have an effortless ride up the hill. faster ,bigger , is not always what it is cracked up to be. (Supersize it It has got to be better)
OH I just thought of another issue with this lift that travels over water for quite a distance. remember you must have a viable Evacuation plan. sounds like you would need a fleet of boats for the evac plan. and each boat would have to have precise station keeping abilitys in all weather conditions to perform the rescues from the water. depending on the capacity of this lift and the stated length ( over 7000 meters!!!) a fully loaded lift having to be evacuated sounds like orwellian night mare
This post has been edited by aug: 17 January 2008 - 11:47 AM
#17
Posted 17 January 2008 - 05:11 PM
Who said that this lift goes over water? Anyway, the loading speed would be the same as the average detatchable quad, give or take 15%.
Posted 17 January 2008 - 08:43 PM
Just a couple of notes, on the Doppelmayr Cable car systems, the drives and returns basically look the same as some of the bigger lift systems (with 4meter wheels), and we have systems running at 12 meters per second and the bullwheel liner does not fly out (average system has 4 bullwheels).
Bearings are all monitored with SPM (shock point measuring) to chart the history of a bearing (all major components, Motors, gearbox's, bullwheels) so you can plan maintenance or replace bearings BEFORE failure.
All of the other problems mentioned are just engineering problems and navigation problems, all probably easy to overcome with longer terminals (to solve the deceleration curve problem) and big boats (for evac), although there are other ways of evacuating a lift. It all comes down to the question WHY? What you are talking about in my mind will be cost prohibitive, there are easier ways to solve your problem. But to answer your original question, Possibley, and could you get an engineer to take up the problem? absolutly, but again why? I am not sure that the Prince here in Qatar has that much money to waste.
This post has been edited by chasl: 17 January 2008 - 08:46 PM
This topic is closed
