This post has been edited by Skier: 07 January 2008 - 09:53 PM
Problems with High Campbell at Crystal
Posted 07 January 2008 - 09:38 PM
Posted 07 January 2008 - 10:05 PM
Snoqualmie guy, on Jan 7 2008, 09:54 PM, said:
With Garaventa CTEC and CTEC lifts, you're hearing the lift's rollback device and that's perfectly normal.
Posted 07 January 2008 - 10:54 PM
Posted 08 January 2008 - 02:48 PM
Posted 08 January 2008 - 04:40 PM
Skier, on Jan 8 2008, 01:38 AM, said:
I can't be sure but from the way you described this happening, It sounds like either the sheave assembly(s) on tower nine or the whole tower itself is out of alignment. Misalignment of a tower would cause the sheaves to wear out improperly which would eventually cause the chair grip to come in contact with the metal rim of the sheaves. This would explain the banging unless it was something else. Anther problem with misalignment is that it makes the haul rope want to twist as it rides over the tower. The happening could possibly cause the carriers to swing as they exit the assembly and therefore this could also explain why the mechanics would want the load on the carriers to be even on both sides. And finally, if the tower were to be out of alignment, the haul rope would be more likely to derail than a tower that is perfectly aligned (obviously). And since this is the tall tower we are talking about, this may explain why they will close the lift with any significant wind.
Disclaimer: The ideas in the passage above are all idle speculation and should not be regarded as fact.
Posted 13 January 2008 - 01:15 PM
1. No single riders
2. Wind hold if wind gusts go above 25 mph
I had to wait a good 30 chairs yesterday until a single came along, and the lift was on wind hold for hours yesterday when the highest wind was about 35 mph. I think it is great that they are being careful, but it seems like there is an underlying problem if single ridersare causing the grips to slip.
Rumor is that a chair with 1 person on it slammed into tower 9 on Saturday and the grip slipped back to within 6 feet of the chair behind it. No one was hurt. The guideage on tower 9 looked pretty smashed up as of yesterday.
This post has been edited by Skier: 13 January 2008 - 01:17 PM
Posted 13 January 2008 - 04:27 PM
Posted 13 January 2008 - 04:39 PM
Posted 14 January 2008 - 06:48 AM
Skier, on Jan 13 2008, 02:15 PM, said:
aug, if this lift used Riblet clips the haul rope would be trashed.
Years ago at JH at closing time one afternoon a Ski Host walked right into the path of a chair coming around the lower BW of a Riblet double.
The ensuing crash was amazing. The chair got tangled up in the first sheave train after the idler and ended up laying in
the maze about 40 feet away.
We dispatched a driver to Bridger Bowl to borrow some parts and proceeded to rebuild the angle iron "gantry" assembly.
Splicer worked there in those days and he salvaged the rope.
The lift got running again by 09:00 the next morning.
The Ski Host was beat up pretty bad and acquired the nickname "Bride of Frankinstein" for a while.
JMHO,
Carl
Posted 14 January 2008 - 04:00 PM
Posted 15 January 2008 - 10:55 AM
Is there a more long term fix to this? If this is the case, I would think a chair slipping down the rope within 6 feet of the next chair would be a major deal. It would have scared the
If the grip slipped due to a impact with the tower caused by unbalanced carrier, then I'm not sure if adding more weight to the carrier by requiring double riders is a fix to the problem.
I've use that lift many times, and would not want to find myself in that situation on any lift, let alone on such a steep lift as that. Hate to say it, but I'm staying off that lift for now. I'm sure the MTX crew is doing everything they can, and I have full confidence in them, but it just doesn't sit well with me.
This post has been edited by Limelight: 15 January 2008 - 11:05 AM
Posted 15 January 2008 - 10:57 AM
aug, on Jan 14 2008, 05:00 PM, said:
My bad, I probably didn't read the report close enough. You are so very correct!
In the incident I recounted above, the clip sure did slip back a bit before "prang"......
Carl
Posted 15 January 2008 - 10:58 AM
Limelight, on Jan 15 2008, 11:55 AM, said:
the key word in that statement is "rumor"
#18
Posted 15 January 2008 - 04:46 PM
Take the above speculation with a grain of salt.
Posted 17 January 2008 - 10:55 AM
Bill, on Jan 16 2008, 10:39 PM, said:
Exactly my point. As is probably true in all circles, rumors spread faster that a common cold bug in a child day care center. Let us try to stick to fact before any judgements of safe operations are speculated.
