Wind Speed Indicators
Posted 24 December 2007 - 06:57 PM
Posted 24 December 2007 - 08:00 PM
skierdude9450, on Dec 24 2007, 09:57 PM, said:
Doppelmayr's UNI-GS detachables can have an CPU generated slow down for wind as an option. They are set in the factory to slow down at 60 kph but that parameter can be adjusted.
Posted 25 December 2007 - 10:12 AM
SuperRat, on Dec 24 2007, 08:00 PM, said:
A wind warning is the first alarm, it just gives an alarm at the Drive station. The next is a wind alarm, this will slow the lift down to 1m/s until the winds drop and the horn reset will clear. The windspeeds are inputed according to each installation, and must stay above that inputed speed for 5 seconds before a warning or alarm will occur.
Posted 25 December 2007 - 11:06 AM
Posted 25 December 2007 - 02:02 PM
skierdude9450, on Dec 24 2007, 07:57 PM, said:
Trust me, you shouldn't. Forward motion combined with an unfavourable wind direction causes more chair swing than you as a rider really want to be subjected to. Add to that the possiblity of a miscapture on a detach, and a slow is always the way to go. The only time I really don't worry about a strong wind is if it is in line with the lift, although a headwind still causes problems for the unloading passengers.
I didn't know one could have the anemometer automatically slow or stop the lift. Makes sense, though- just one more input in the cabinet and a few extra lines of programming.
Posted 25 December 2007 - 03:16 PM
Great point i was going to say the same thing... We had a strong head wind this past week and it was pushing the cabins threw the departure side... I had 5 or more piggybacks come down the hill... I'll take a cadence chain over a tire turnaround anyday...
Posted 26 December 2007 - 03:34 PM
Posted 26 December 2007 - 04:04 PM
liftmech, on Dec 26 2007, 06:34 PM, said:
We put in the double clutch’s or one on the second half a few years back on one of our detaches, (the chairs would blow through the spacer with high winds), and we have been going to (not yet) put the Zern from the top on the second half of the return so we would have the entire contour at the return to help with respacing.
Posted 26 December 2007 - 04:16 PM
liftmech, on Dec 26 2007, 04:34 PM, said:
John, doesn't the arrival half of your contour freewheel at the return terminal? (you can push carriers ahead, but not hold back) I know it doesn't do you much good when you're at the top, but if you have a good operator down there that has a pretty good idea of what the chairs should look like in station they can help.
Posted 26 December 2007 - 05:24 PM
skierdude9450, on Dec 25 2007, 01:44 PM, said:
Good question and I would bet no one can answer it, not accurately anyway, it all depends on the lift (many parts to this); the wind direction, the frequency of the gusts (it’s like pushing someone on a swing, push at the right time and it accelerates the motion) and the size of you’re….. Oh forget that part, anyway, as a coworker use to say; you will never know the limits of a machine until you upset it, and to me this means that until you learn the machine you will not know its capability.
Posted 26 December 2007 - 09:10 PM
While such a program loop could provide a very useful automatic function, it might also open a bag of legal worms the first time the algorithm fails to prevent a mishap. Which name will be "on the bottom line"? I'm not sure that I'd want it to be mine.
Posted 27 December 2007 - 10:01 AM
Riming of the anemometer's cups or blades should be carefully monitored. You Pac NW guys know all about that!
You know its time to shut down when the Anemometer blows off
This post has been edited by RibStaThio: 27 December 2007 - 10:02 AM
Posted 27 December 2007 - 11:10 AM
Posted 27 December 2007 - 04:42 PM
lastchair_44, on Dec 26 2007, 05:16 PM, said:
Mine doesn't, actually. The first gear in the contour is bolted to the last belt sheave and one has to undo all three bolts in order to make the contour freewheel. There's no one-way bearing there.
Posted 27 December 2007 - 04:44 PM
RibStaThio, on Dec 27 2007, 11:01 AM, said:
We actually had that happen last year! The peak recorded gust at the top of Storm King was about five seconds before the station went off line. We found the anemometer hanging by its wire on the mast later, after it had calmed down enough to drive up there.
#18
Posted 27 December 2007 - 06:47 PM
liftmech, on Dec 25 2007, 03:02 PM, said:
I guess I don't understand how a moving carrier is in more danger running fast, than slow (except for the fact that it determines how hard the swung chair hits the tower). Think of Newton: combine two simple velocity vectors (one for wind, and the other for the carrier speed) into one. Thus, the "wind" could be as much as 1,100 fpm faster, or slower. Please explain what you mean when you say the chairs swing more.
Emax, I think I know where that anchor chain used to hang. But I never saw the chain. Didn't you guys put it back up after that one day?
#19
Posted 27 December 2007 - 10:32 PM
See attached pic
#20
Posted 28 December 2007 - 08:03 AM
