Posted 27 February 2004 - 07:22 PM
We have about three dozen of those 'jet winches' left over from various lift construction projects. An interesting note about embedded towers- Copper's lift guys were so well-versed in that type of tower footing after eight Yans that they got Poma to let them build the Eagle and the Flyer that way. Those are the only Poma detachables I've seen without a bolt cage footing. (K, L, and A-1- fixed-grip Poma triples- are also built that way.)
We should note that although Riblet's bolt drum is designed for tower alignment, it is the initial construction they had in mind. The sheaves are still aligned in the standard fashion up on the cap.
