Info about Silverlode Chair at Red Mountain
3 replies to this topic
#1 skikyle
  • 2 Posts:
Posted 06 November 2007 - 05:45 PM
Hi there,
I am a Ski Resort Operations and Management (SROAM) student at Selkirk College in Nelson. One of our projects is a Technical Description of a Chairlift. My group has choosen to do this report on your new fixed grip quad chair, Silverlode. I am looking for some information on this chair. I am willing to send you a copy of this report upon completion for you to have a look at to see how we used the information you have provided.
The info I need is as follows:
The haul rope- length, lay, diameter
Towers- how many towers total,
Sheaves assemblies- how many individual sheaves, how many towers have hold down sheave assemblies, support, combination
Haulrope tensioning system, location
Drive Line- couplings, hi speed rollback, drive shaft and gear reduction components
Prime mover- manufacturer, specifications and description. Power source including motor operating voltage
Drive controller for the prime mover
Evacuation drive and method of linkage
Safety circuit- operator controls, limit switches, derailment devices
Braking systems- Service Brake, E-Brake, Anti-rollback device
Grips- type example riblet
Carriers- how many
Chairlift operator communications system
Thank you for your time and any information you can provide
Kyle Fossett
#2 Allan
Posted 06 November 2007 - 06:11 PM
I could probably answer these...
View Postskikyle, on Nov 6 2007, 05:45 PM, said:
Hi there,
2327 metres of 1.5" Right hand Langs lay
17 + the drive portal
2 hold downs, 4 combinations - see attached tower PDF for the rest. Sheave config is at the right on the unrotated view under the U and L's
Bottom hydraulic tensioning
Chain coupling on Evac, Belts on electric, no HS rollback, SEW Eurodrive primary gearbox, Cat D11N secondary.
Reliance 300hp 1725 RPM 600 volt, source before step down transformers is 2.4 kv.
ABB DCS 525
Cummins B3.3T 85 HP Diesel, chain coupling
Control system made by Doppelmayr actual buttons made by Allen Bradley, don't remember limit switches, derailment switches are Doppelmayr brittle forks
Service brake is a Nexen hydraulic disc brake (don't know model), E-Brake is a dual jaw on Bullwheel flange, Rollback brake is a single jaw on BW flange.
Doppelmayr FG4
Carriers- how many
102 with a max capacity of 174
Sound powered phones, standard dial phones & bells.
No problem, ask any more questions if you have any! Also see other attached general data PDF.
Kyle Fossett
#3 skikyle
  • 2 Posts:
Posted 07 November 2007 - 05:25 PM
Allan thank you for the info. This will help with the assignment greatly. Kyle
#4 Allan
Posted 07 November 2007 - 10:36 PM
No problem, feel free to ask any more questions you may have... and say hi to Peter Wood for me :)
