High Speed Doubles?
11 replies to this topic
#1 JustJeepIt
  • 132 Posts:
Posted 01 July 2007 - 10:54 PM
I've seen High Speed Tripples and Quads, and 6's, but are there any high speed doubles out there?
#2 Peter
Posted 01 July 2007 - 10:57 PM
Yes, but I do not think there are any in North America. Ruthie's at Aspen is sometimes loaded as a double, but technically it is a triple.
#3 spunkyskier01
    industry trainee
  • 379 Posts:
Posted 02 July 2007 - 06:16 AM
their are quite a few over in Europe, search liftworld.info for pics.
Everything is just loop-de-loops and flibertyjibbit
#4 Emax
Posted 02 July 2007 - 06:36 AM
Since you did not specify "detachable" in your question, the correct answer is: when compared to all other fixed-grip lifts, except single-chairs, virtually all doubles are high speed. The maximum fixed-grip speeds under B77.1 are:
Single chair: 600 ft/min
Double chair: 550 ft/min
Triple chair: 500 ft/min
Others: 450 ft/min
This post has been edited by Emax: 02 July 2007 - 06:46 AM
#5 Lift Kid
Posted 02 July 2007 - 07:48 AM
Others: 450 ft/min
Way to be technical Emax!!! :laugh: You should post a topic about using the proper lift terminology.
#6 Emax
Posted 02 July 2007 - 07:59 AM
I have - several times.
#7 Lift Kid
Posted 02 July 2007 - 08:00 AM
You should bring one back up on top!
#8 JustJeepIt
  • 132 Posts:
Posted 02 July 2007 - 09:53 AM
Yes, I was referring to the detachable so I'm sorry for not using the correct terms there. Thanks for the info gang.
#9 dromo_mania
  • 35 Posts:
Posted 02 July 2007 - 05:35 PM
You often see detachable doubles in Japan. Try Googling Katashina or Nozawa-Onsen. I've ridden one but I can't remember which ski area I was at..
#10 BernardP
  • 10 Posts:
Posted 20 July 2007 - 12:14 PM
Well, this topic gives me an occasion to post for the first time on this forum.
There was actually a detachable double installed at Mont-Sainte-Anne near Quebec City in the early 1970's, alongside the bottom-to-top gondola. It was built by a local company (unsure between Samson and FX Drolet), based on a european design who had never been in use before.
EDIT: The chair was high-speed. It took 10 minutes to reach the top vs 20 minutes for the Mueller gondola
I knew a guy who was working for the company (let's say it's Samson). The system to keep the distance between chairs constant was based on rotating mirrors. It generated a lot of problems and chairs tended to bunch up in clumps.
Still, the mountain persisted in using it until an accident happened in its first or second year of operation. A chair slipped on the cable and hit the chair behind, then both fell to the ground (sounds familiar?). People were seriously injured and I think there was one dead. I started skiing at MSA the year after this accident happened.
The chair was idle for more than a season then was eventually transformed into a fixed-grip double. In the mid 1980's, it was shortened and moved to its present alignment in the Sept-Chutes trail, in the expert area of the Mountain. It is still working after about 37 years.
I would be really interested if anyone else had more info about this historic lift which was certainly the first detachable chair in America.
This post has been edited by BernardP: 22 July 2007 - 04:22 PM
#11 SkiBachelor
Posted 20 July 2007 - 05:18 PM
I'm pretty sure Riblet built the first detachable double at Mt. Spokane, although it wasn't high speed.
#12 seilbahnbilder.ch
  • 152 Posts:
Posted 29 August 2007 - 01:10 PM
In Melchsee-Frutt (Central Switzerland) you can find two detachable doubles!
2-CLD/B Cheselen & 2 CLD/B Jäst
Some pictures:
http://www.seilbahnb...ls.php?album=26
and an other one in Engelberg (Central Switzerland) (replaced by a new chairlift in 2008)
2-CLD Engstelnalp
Some pictures:
http://www.seilbahnbilder.ch/galerie/displ...m=27&pos=37
http://www.seilbahnbilder.ch - the website about skilifts in Switzerland!
