Trams
13 replies to this topic
#1 Snoqualmie guy
    Snoqualmie guy
  • 1,065 Posts:
Posted 29 April 2007 - 04:17 PM
Why are trams worth the price? They don't seem to have a high PPH rating, compared to a gondola or a chairlift. I know that they are for long steep places, but why can't they put in a gondola?
- Jeff
#2 SkiBachelor
Posted 29 April 2007 - 04:34 PM
Trams are able to operate in conditions that would normally shut down a gondola or chairlift.
Trams are more expensive because they are custom built, complex and have a lot of haul rope. A tram is also able to span large gaps which normally isn't possible with other types of lifts.
#3 liftmech
Posted 30 April 2007 - 04:48 AM
You nailed it in your question, snoqualmie guy. Trams are for long, steep places, many of which are unsuitable for a more 'traditional' lift. A grip, either fixed or detachable, can only hold its carrier on until a certain steepeness (varies with grip type). The haul rope on a tram is permanently clamed on with much more force than a fixed or detachable grip. There's also a lot more steel in a tram. Check this one out- the top of the Snowbird tram.
#4 ccslider
    ccslider
  • 186 Posts:
Posted 30 April 2007 - 08:11 AM
The other option for long spans is a funitel type installation - this allows for more capacity than a tram. Is it worth the $$? Ask Squaw Valley. I'm sure there's some marketing value beyond the capital $/capacity issue.
#5 EagleAce
  • 716 Posts:
Posted 03 May 2007 - 11:13 PM
What is a funitel? I've seen 'em mentioned a lot.
#6 floridaskier
Posted 04 May 2007 - 02:52 AM
It's a continuous loop gondola (not like a tram, the cabins keep moving around like a regular gondola) but the cabins are suspended between two haul ropes for better wind stability and longer spans. Squaw Valley has the only one in North America, but there are more in Europe
http://www.skilifts.org/images/resort_imag...tel/funitel.htm
#7 Lift Kid
Posted 04 May 2007 - 01:58 PM
In some cases, trams are a good choice because the ground underneath them is too unstable or too steep for chairlift or gondola tower foundations to remain in place. Trams only have several towers and can sometimes span a couple of miles between towers.
#8 dh_lift_op
  • 50 Posts:
Posted 04 May 2007 - 06:30 PM
Is that what the peak-to-peak at WB is gonna be?
#9 Peter
Posted 04 May 2007 - 06:34 PM
No. The funitel has 2 cables spaced apart on each side of the cabins, the peak to peak has 3 cables in a cluster above the enter of the cabin.
#10 Carl
  • 302 Posts:
Posted 08 July 2007 - 07:12 AM
Yup, Trams are cool....
JH Tram Construction image from the mid '60's
This image is most likely from the first winter's operation; '66-'67
I skied there that first season. I was awe struck!
Carl
#11 Snoqualmie guy
    Snoqualmie guy
  • 1,065 Posts:
Posted 08 July 2007 - 12:11 PM
I've been up that one in early july and there was still plenty of snow up there. It was one of the better tram rides I've been on.
- Jeff
#12 mikest2
    Mountain Operations
  • 1,204 Posts:
Posted 09 July 2007 - 06:29 PM
Carl
I would not want to be the guy in the toboggan being loaded onto the cabin roof !
...Mike
#13 Snoqualmie guy
    Snoqualmie guy
  • 1,065 Posts:
Posted 10 July 2007 - 10:03 AM
He was most likely out of it. What if he was to wake up and try to get up.
- Jeff
#14 EagleAce
  • 716 Posts:
Posted 10 July 2007 - 10:10 AM
"Watch that first step--it's a whopper!" :w00t:
