New Lift Construction Photos 2007
607 replies to this topic
#481 Allan
Posted 23 October 2007 - 06:44 PM
 Lift Kid, on Oct 23 2007, 01:34 PM, said:
Looks good! It's funny to see a new lift with buttons that aren't colored legally in the US for new lifts!!!! :smile:
It was built in the US for US codes, right down to the annoying start horn that'll be unplugged soon enough :)
What colours are not legal? Red = stop, Yellow = slow, Green = go; I thought those were the ones that mattered, I never did know for sure.
#482 lastchair_44
  • 1,159 Posts:
Posted 23 October 2007 - 06:48 PM
Does it sound like a European car alarm?
-Jimmi
#483 Allan
Posted 23 October 2007 - 07:02 PM
Haha, I can't remember what one sounds like! But it's annoying; and there's nothing I can find in the (Canadian) code about keeping it! On top of that every single Sonalert beeps for the same amount of time, so its not like there's no warning!
#484 lastchair_44
  • 1,159 Posts:
Posted 23 October 2007 - 07:34 PM
Is there one of those nifty Wago relay modules in the low voltage you can pull for the start alarm?
-Jimmi
#485 Allan
Posted 23 October 2007 - 07:38 PM
I don't mind the sonalerts, but the horn you can hear for about 1000 ft in every direction.
#486 SkiBachelor
Posted 23 October 2007 - 07:52 PM
Allan, why is your new lift bottom drive rather than top?
#487 Allan
Posted 23 October 2007 - 07:57 PM
The bottom line was cost; the closest power to the top station is half a mile a way so to put in a trench and the wiring would have been pretty expensive. We thought it would have been worth it.
#488 Shawn
  • 262 Posts:
  • Interests:Many
Posted 24 October 2007 - 12:38 PM
I hate those things too! Does the horn have an allen head adjustment screw on it? If so tighten that sucker up and your problems are solved.
#489 Lift Kid
Posted 24 October 2007 - 02:31 PM
I believe it is the signal button that the code changed.
#490 Allan
Posted 24 October 2007 - 04:17 PM
I don't know - but I'll sure look!
Ahh.. we have black signal buttons, blue ones, and red ones spread around the resort.
#491 Lift Kid
Posted 24 October 2007 - 04:25 PM
I think there is something in the code about all buttons having to be different colors. I am not sure though.
#492 RibStaThiok
Posted 24 October 2007 - 05:53 PM
Gotta love the little buzzer bells which work much better then the bloody horns.
#493 poloxskier
Posted 24 October 2007 - 08:36 PM
I am not sure of the new ANSI color standards but the thing to keep in mind is that ANSI is not law it is a standard by which states do not have to write into law, some do such as colorado in part, but it is not a legal issue because the state regulatory body can either adopt ANSI B77.1 or choose to set their own standard. So for legality you need to refernece the state, or provencial regulations depending on who the authority having jurisdiction is.
This post has been edited by poloxskier: 24 October 2007 - 08:38 PM
#494 liftmech
Posted 25 October 2007 - 05:39 AM
Plus the Z98 up there may not have the same provisions in it as the B77 down here, although the two are pretty close.
#495 SuperRat
  • 311 Posts:
Posted 25 October 2007 - 01:20 PM
Its been a busy week at Loon's South Peak. On Monday we flew tubes and tower heads for our two new lifts: 57 picks in ten hours. Today after completing an unrelated cable shortening (North Peak) I dropped in at the base of South Peak and found most of the steel and machinery for the bottom drive terminal has been assembled. Both detachable terminals are now ready for enclosures. Also, the return-tension bullwheel for the fixed grip was placed last week, the haul ropes arrived yesterday and the fixed grip drive terminal should arrive today or tomorrow. Enjoy the pictures.
Attached File  new_lifts_10_22_07_006.jpg (195.17K)
Number of downloads: 36Attached File  new_lifts_10_22_07_014.jpg (43.58K)
Number of downloads: 27pg]Attached File  new_lifts_10_22_07_022.jpg (205.34K)
Number of downloads: 102Attached File  new_lifts_10_22_07_036.jpg (168.89K)
Number of downloads: 586.jpg]Attached File  new_lifts_10_22_07_054.jpg (71.93K)
Number of downloads: 22Attached File  new_lifts_10_22_07_061.jpg (189.96K)
Number of downloads: 33_061.jpg]Attached File  new_lifts_10_22_07_111.jpg (254.5K)
Number of downloads: 34Attached File  new_lifts_10_22_07_118.jpg (79.42K)
Number of downloads: 19_07_118.jpg]Attached File  new_lifts_10_22_07_121.jpg (135.34K)
Number of downloads: 34Attached File  dscf0034.jpg (253.96K)
Number of downloads: 21jpg]Attached File  dscf0035.jpg (264.43K)
Number of downloads: 21Attached File  dscf0036__2_.jpg (189.4K)
Number of downloads: 17[attachmen
=13405:dscf0038.jpg]Attached File  dscf0040.jpg (257.75K)
This post has been edited by SuperRat: 25 October 2007 - 01:36 PM
#496 skisox34
  • 339 Posts:
Posted 26 October 2007 - 08:02 AM
What is with the offset towers? Is there going to be a midstation??
#497 SuperRat
  • 311 Posts:
Posted 26 October 2007 - 12:21 PM
Not exactly. This lift will load skiers in both directions. The offset lines will allow skiers unloading at the drive end to pass underneath the opposite line of chairs which will load at the bullwheel. All the elements can be seen in the photo: Skiers load at the bullwheel (the empty mast is seen far right) and ride west to South Peak; The return line begins the offset at tower 3 (left side of frame), continues deflecting at tower 2 where riders unload and at tower 1 the offset is only in the sheaves (the loaded side is depressed and the unloaded side is supported), the ropes are level. At the return end of the lift, loading and unloading is at the bullwheel so there is no offset.
This post has been edited by SuperRat: 26 October 2007 - 12:27 PM
#498 Peter
Posted 02 November 2007 - 06:06 PM
Liftmech or anyone else know anything about Crystal? They said the towers were to be flown this past Tuesday, then Wednesday, then Friday and they were going to let me know the day before. I didn't hear from them and there isn't anything about the towers being up on the website. Anyone know if it has been done? I think I'll go up on Sunday and see what's up.
#499 Peter
Posted 03 November 2007 - 01:44 PM
Here is a new video of the Dakota Lift construction at Big Sky:
http://www.youtube.c...h?v=QZ0s-iJHMsc
#500 Peter
Posted 04 November 2007 - 10:35 AM
ok I am at crystal now. Towers are still in the parking lot. They have actually taken the crossarms off of the tubes!
9 User(s) are reading this topic
0 members, 9 guests, 0 anonymous users
