When looking for points to ponder, I came across this from my email archive. There must be some equally funny entries on some of our lift log sheets.
I remember one from an unnamed area. 9:00 gearbox leaking oil, 10:45 gearbox oil leak slowed to a drip, 11:30 gearbox oil no longer leaking, 12:05 lift stopped, will not restart.
Here are some actual maintenance complaints submitted by U.S. Air Force pilots and the replies from the maintenance crews. "Squawks" are problem listings that pilots generally leave for maintenance crews to fix before the next flight.
(P)=PROBLEM
(S)=SOLUTION
(P) Left inside main tire almost needs replacement
(S) Almost replaced left inside main tire
(P) Test flight OK, except autoland very rough,
(S) Autoland not installed on this aircraft
(P) #2 Propeller seeping prop fluid
(S) #2 Propeller seepage normal - #1, #3, and #4 propellers lack normal seepage
(P) Something loose in cockpit
(S) Something tightened in cockpit
(P) Evidence of leak on right main landing gear
(S) Evidence removed
(P) DME volume unbelievably loud
(S) Volume set to more believable level
(P) Dead bugs on windshield
(S) Live bugs on order
(P) Autopilot in altitude hold mode produces a 200 fpm descent
(S) Cannot reproduce problem on ground
(P) IFF inoperative
(S) IFF always inoperative in OFF mode
(P) Friction locks cause throttle levers to stick
(S) That's what they're there for
(P) Number three engine missing
(S) Engine found on right wing after brief search
(P) Aircraft handles funny
(S) Aircraft warned to straighten up, "fly right" and be serious
(P) Target Radar hums
(S) Reprogrammed Target Radar with the words
Squawks
Started by mikest2, Mar 07 2007 07:25 PM
No replies to this topic
