2006 Lift Installation Survey
Started by SkiBachelor, Feb 23 2007 03:54 PM
13 replies to this topic
Posted 24 February 2007 - 07:59 AM
cameron,
should you add the BC gondola? its partially done, but they only have to string the cable and add the cabins.
Posted 24 February 2007 - 12:44 PM
I usually don't classify relocated lifts unless they're more than 75% new.
Do you have the stats for the Breakaway Quad at Wolf Ridge/Laurel? For some reason, Doppelmayr's installation survey didn't list the stats for this years lifts or atleast the version I got.
As for the new gondola at Beaver Creek, once it's finished I'll add it. :)
Posted 27 February 2007 - 05:22 PM
skierdude9450, on Feb 27 2007, 03:38 PM, said:
For Elevation at Sun Peaks it says it is 1118 feet long with 1024 vert. That must be incorrect unless it has an 80 some degree slope.
I was wondering about that too since I have a hard time believing that's correct. I've seen the lift line and it's not that steep so I think some numbers got mixed up.
SAM's 2006 lift installation survey had SEVERAL errors to it, leaving out the providence British Columbia, failing to give the correct vertical rise for some lifts, listing the capacity as the speed of the lift. It's almost like it was done in a hurry and was never checked for errors.
Posted 28 February 2007 - 05:28 AM
One more quad at Baker... one double left until they are a quad-only ski area. When that happens their oldest lift will be a '90. At least someone understands the value in upgrading old equipment.
Posted 10 March 2007 - 12:02 PM
Wolf Ridge's Quad is a 1800 pph Lift, with a Sprint Drive and eclipse return, 100 hp motor, speed:most likley 400. The vertical: I'd say about 200 to 400 feet
Number of downloads: 17 -
Number of downloads: 18 -
This post has been edited by Warren733: 10 March 2007 - 12:04 PM
Posted 02 April 2007 - 06:24 PM
EricEurope, on Feb 28 2007, 03:08 AM, said:
The survey is really interesting!
But there are 2 points I have to mention:
I thought Over Easy at Stowe would be a 10-person Gondola?
And according to Northstar website Tahoe Zephyr is a simple Six-pack and not a chondola at a length of 4334ft.?
Stowe Over Easy IS a 10 person gon. I go there every year. It's much more convienient than the bus to get from mountain to mountain.
-Sam
FPS Doug said:
I heard the army is like FPS but with better graphics. What happens if I get lag out there? I'm DEAD! And I heard there aren't even any respawn points out there.
Posted 02 April 2007 - 06:29 PM
They look like 4 person gondola cabins to me:
https://zeus.pomagroup.com/cpg149/displayim...bum=6&pos=4
