2milehi, on 14 March 2012 - 11:29 AM, said:
Any reason for that weekly test? When I was at Keystone there was no weekly test for Reverse. Summer maintenance was the only "test".
I would think that if you have the capability to run in reverse- and plan to use it in some instances- that you would have a written procedure for the task (just like running your evac) and perform the operation on some type of regular basis (Weekly? / Monthly?)
Fairly simple way to avoid the proverbial 'Chinese Fire Drill'.
If you're only going to use it for summer maintenance, all maintenance personnel should still be aware of the correct procedure.
$0.02
