High-speed Quad
Posted 02 December 2006 - 09:58 AM
When solid-state radios first came out, they were called by the parent industry "transistor radios" - because that was the salient element in their design. Soon, nearly every freshman was calling them "transistors" - leading to a mass misunderstanding of just what a transistor was.
Other mass nomenclature difficulties include:
4WD or four-wheel drive - a rear drive only pickup with "dualies" is indeed a 4WD... isn't it?
FWD is even worse - it might mean "front-wheel-drive" or "four-wheel-drive"
VFD - for "variable frequency drive". What's really meant is "inverter drive" - one that creates AC wave forms from DC... at a selectable frequency. Worse yet, it's often called an "AC drive".
DC Drive - this might include quite a variety of schemes to control a DC motor. Usually, it refers to a phase-angle controlled SCR unit, but there are many othertypes that are in use.
TURBO - this is a good one. It's really a prefix for any device that employs a "turbine". There is no "turbo" in your computer - or in anything else that does not use turbine power.
CRT - to most today, this means a monitor that is not flat. What does CRT really mean? "Cathode Ray Tube", that's what. It's the picture-presenting element in most existing televisions and radars.
There are lots of others - we mis-use them every day. Eventually, few of us will know what any term really means.
Posted 02 December 2006 - 10:28 AM
Some examples are:
Yo Yo
Frisbee (Frisbee created the flying disk, but people like the name Frisbee better)
Xerox (A lot of people use the term "I'm going to Xerox this piece of paper")
Posted 02 December 2006 - 10:37 AM
SkiBachelor, on Dec 2 2006, 10:28 AM, said:
Some examples are:
Yo Yo
Posted 02 December 2006 - 08:48 PM
Emax, on Dec 2 2006, 05:30 PM, said:
By the way, there's a new Crescent design that sounds pretty good. Here are the details:
"The RapidSlide™ adjustable wrench helps get jobs done quickly and easily with just a flick of your thumb. The slide control in the handle provides smooth, fast, and accurate jaw adjustment. Simply slide forward to close, back to open. The RapidSlide™ has a large 1" jaw capacity for maximum versatility with precise laser-etched size markers for both SAE and metric-sized fasteners. Plus, it has an extra-wide handle for exceptional comfort, strength, and bolt-busting power.
- 1" jaw capacity
- Internal debris shield keeps out contaminants
- Extra-wide handle for comfort and more force
- Drop-forged construction for maximum durability
- Polished head makes cleanup easier"
My theory on the Crescent wrench...........
"If a Crescent wrench fits, you have the wrong tool"
Posted 03 December 2006 - 02:50 PM
With forklifts you can see the same thing sometimes with Hyster.
Posted 03 December 2006 - 06:36 PM
Posted 03 December 2006 - 06:59 PM
Posted 03 December 2006 - 08:22 PM
Posted 03 December 2006 - 08:46 PM
I have heard many people refer to SUVs and even Vans as Trucks.
Posted 04 December 2006 - 07:08 PM
You're right, of course. As many a scarred knuckle and rounded hex will testify, no adjustable wrench should be used to make anything tight... or for that matter to loosen anything that is tight. For such jobs, a Channel-Lok plier should be used.
I have to admit, for a guy that hates crescent wrenches, I carry a pair of 4" channellocks(real blue handles), they fit up to 13mm(1/2" for my American cousins), I don't think I could live without them.
Posted 05 December 2006 - 01:31 PM
Emax, on Dec 5 2006, 01:18 PM, said:
You'll notice that the signs on the highway referring to the use of these deveices always refer to them as 'compression brakes' - due to the fact that Jake Brake is a registered trademark.
