This post has been edited by poloxskier: 02 March 2005 - 07:26 PM
85 replies to this topic
#41
Posted 02 March 2005 - 07:25 PM
Probably the highest for me for a gondola would be the old Lionshead at Vail, it seemed especialy high when you sit up there for about two hours swaying in high winds plus I was much younger then so it probably seemed much higher. For a tram it would be the Klein Matterhorn tram in Zermatt that ends in the side of the mountain.
#42
Posted 02 March 2005 - 07:55 PM
For me it might be the Peak 8 SuperConnect, or maybe the gondi at Steamboat. They don't seem high, but when the lift stops and you look down...
#43
Posted 02 March 2005 - 07:58 PM
Near the top of the super connect over the run tiger is really high as was chair 4 the old riblet that it replaced.
#44
Posted 02 March 2005 - 08:04 PM
I believe that the SuperConnect was the first lift I rode on that had the three seperate poles, bolted together.
#45
Posted 10 August 2006 - 09:22 PM
We've talked about low lifts, now let's talk about high lifts.
I'd say that the highest open-air lift that I have been on is either Resolution at Copper or Peak 8 Superconnect over one span where it has a triple-segment tower.
The highest gondola I've been on hands-down is the Silver Queen Gondola at the lattice tower with two heads on it. That has to be near 200 feet.
#47
Posted 11 August 2006 - 05:43 AM
The last span on the Riva Bahn at Vail is hands down the highest chair in the state of Colorado.
#51
Posted 11 August 2006 - 03:08 PM
I'm not sure of specifics, but I know that the Slide Brook Express crosses some pretty deep valleys over it's 2 mile length.
#54
Posted 11 August 2006 - 07:37 PM
Skidude, on Aug 11 2006, 06:23 PM, said:
The Panorama Gondola at Mammoth mountain is the highest lift I have been on. The highest chairlift is Red Dog at Squaw Valley.
does the cable car at squaw go higher than the mammoth gondola?
<!--coloro:red--><span style="color:red"><!--/coloro-->-Christian<!--colorc--></span><!--/colorc-->
<a href="http://www.myspace.com/the_skiing_beast" target="_blank">http://www.myspace.com/the_skiing_beast</a>
#55
Posted 11 August 2006 - 08:54 PM
Gondolas:
Aspen's
Steamboat's (Past the first crest is really high)
I agree with you on Vail's gondi and Keystone's River Run
Chairs:
Resolution at Copper after the depression sheaves up the steep part
American Flyer at Copper has about two high points a couple towers after the bead tree
That new 6 pack at Mary Jane (name slips my mind) has some high points towards the top where it traverses the hill
Aspen's
Chairs:
#58
Posted 12 August 2006 - 07:05 PM
Right in the red area is one spot...
#60
Posted 13 August 2006 - 04:51 AM
The highest chair I have been on is the Millicent lift at Brighton, UT between towers 12 & 13. Since the chairs are center-bar double, you can look off to the side and see straight down. The first time I rode that chair, they did an E-stop while I was going over that section. I quickly grabbed the center bar (even after nearly 30 years of riding many different types of lifts). It will be interesting to see how they engineer that section if/ when it is replaced by a HSQ.
Another high chairlift is the Argentine at Keystone (I have forgotton tower numbers) when it passes over the creek about 1/2 way up. The side-bar style double chairs take away some of the effect compared with Brighton's lift.
