400-hour terminal service
-grease all cadence drive shafts
-grease both bullwheels
-grease the high-speed shaft
-double-check the rope-to-rail measurements and adjust as needed
-check the 'parachute' safety valves on the tension rams (these are what would lock the rams in place in the even of a major hydraulic hose rupture)
-check critical bolts for tightness
600-hour grip service
-grease mobile jaw axle, compression roller (that's the small one on top of the mobile jaw), and chair head axle
-inspect traction plate, principal rollers, and lateral rollers for tightness
-inspect grips springs
-check bail-to-hanger bolt (the Jesus bolt, as in 'Jesus, that's all that's holding us up??)
Of course, since none of these items can be performed while the lift is running, I'm getting lots of OT right now (and cold dinners as well
