Possible New Lifts for Summer 2007
#301
Posted 20 March 2007 - 02:46 PM
U.S. Forest Service approvals allow the Skico to remove trees on an 8.5-acre area on the lower Turkey Trot trail for the beginners area. A quad chairlift will serve the area."
Posted 20 March 2007 - 05:34 PM
Arrow-Comstock Replacement - http://www.placer.ca.gov/upload/cdr/ecs/ne...omstocklift.pdf
S Pod Lift On The Backside - http://www.placer.ca.gov/upload/cdr/ecs/ne...nstarskipod.pdf
#303
Posted 20 March 2007 - 07:58 PM
SkiBachelor, on Mar 20 2007, 12:13 PM, said:
http://www.aspentimes.com/article/20070319...044/0/FRONTPAGE
Until I went and read the article, I was thinking, "Whoa, replacing the Sheer Bliss lift with a HSS would possibly be the greatest lift over-kill since McConkey's at PCMR."
After reading I see that they were considering a single lift replacement of a HSS to replace both the Big Burn HSQ and the Sheer Bliss FGD all in one shot. That makes a lot more sense, however, I think its probably better to leave things as-is, as sometimes the HSS's are more trouble than their worth. It would preserve the ski experience better with a HSQ and a fixed-grip both in their current alignments. Sometimes faster isn't always better.
#304
Posted 20 March 2007 - 10:39 PM
afski722, on Mar 20 2007, 08:58 PM, said:
The ski patrol apparently did not like the new alignment since the line would've gone right up the advanced Garrett's Gulch. Since The Burn is primarily intermediate terrrain they were concerned about evacuating into an advanced area that also has the potential for slides. Garrett's Gulch is presently closed due to avalanche concerns from the warm weather.
The Village Express 6-pack is a nightmare lift in my opinion. They badly need the conveyor belt loading. The gates open and people just don't understand that you need to proceed to the red line for loading. It's a painfully slow because of the slow downs and stops from loading and unloading problems. Also, from my experience they seem to run it at less than full speed.
The best scenario is to replace or rebuild The Burn HSQ and replace Sheer Blisss with either a HSD or a reduced capacity HSQ (1200 - 1800 pph). If it must be a fixed grip lift then I'd rather keep the Riplet. They replaced the Campground lift with a new Poma FGD and it is painfully slow. I also don't understand why they run it so slow since it no longer is a center pole and the carriers are spaced farther apart than the old Riplet lift. If the public can't ride this lift at full-speed then they should just have their lift priviledges revoked or be banned to the detachables.
This post has been edited by egieszl: 20 March 2007 - 10:41 PM
#305
Posted 21 March 2007 - 04:48 AM
I thought the Campground lift was slow as well. It may have just felt that way since the lift was so long. I don't think it has anything to do with people who can't load since it serves only advanced-expert terrain.
#306
Posted 21 March 2007 - 04:27 PM
People just cannot load HSS for some reason. All of the HSS s I have ridden on in Colorado stop and slow all the time and take more time to get to the top than it would take to ride a 30 year old fixed-grip chair. The only HSS which seems to run efficently is the Super B at Copper. (The only HSS which is forward-loading). Misloads in general also seem to be on the rise. It has been a very annoying issue this season, especially on lifts which serve only intermediate and advanced terrain. I can't understand why people cannot pay better attention to what they are doing and have a little more consideration for others. Constant misloads causing lifts to stop and slow constantly cause massive lines at the bottom! Definately a good quality improvement project for many ski areas.
#307
Posted 21 March 2007 - 06:06 PM
Posted 21 March 2007 - 06:18 PM
Skier, on Mar 21 2007, 08:06 PM, said:
Does the Forest Queen have forward-facing loading or the 90 degree loading?
#311
Posted 21 March 2007 - 06:54 PM
I agree with you 100%. The HSS just don't seem to work the way they were intended at a lot of these places. Part of it is the side load, part of it is the gates, part of it is the unloading area, and part of it throwing a bunch of random people together on a chair. Colorado has more issues than other places just because of the caliber of skiers.
A HSS as a single lift replacement on Burn/Bliss is a bad idea. I didn't realize they were looking at running it up the Gultch - what a stupid idea that is for so many reasons. Environmentally, from a safety perspective, and ruining a somewhat decent expert stash on the mountain. I for one have no problem riding fixed grips as it helps to mellow out the pace and can allow for better conversations, plus can usually be faster that High-speeds since the crowds will avoid them. Skico is wise at re-evaluating this idea. I think they have bigger problems in figuring out what to with the Alpine Springs and Elk Camp areas first before changing things up on the Burn.
#312
Posted 21 March 2007 - 07:41 PM
Exactly SkiBachelor's point. The people that ski at Crystal are much more competent at riding the lifts than around here. At Breck, they get double time to get on the chair and they still can't, but also so many people fall down getting off of the chair that you could have a blooper reel in 10 minutes of filming.
I noticed looking through the gallery that Squaw's sixes don't have loading gates. If anyone is from Squaw, or has been there, does this help?
As boardski said, Super Bee never has a problem. I think it might have slightly reduced capacity. (yes, no?) Ruby at Keystone is hassle free except at the end of the day when it actually gets used and people can't figure out that six people can fit on the chair, and also when they load the wounded onto the two stretcher chairs. I'll have to get a picture of that.
I'm not sure how much 90 degree loading affects the effeciency of the lift, but you don't have as far to get to the "load here" board. That can be good and bad. But why are so many lifts these days especially L-Ps made with 90 degree loading? Overall, everywhere needs lift-ops like Copper's that can form sixes and keep reminding people to move out to the chair.
Anyway, now that we're so
#314
Posted 22 March 2007 - 02:34 PM
Posted 01 April 2007 - 01:58 PM
The mountain also mentioned in a letter to passholders that they will upgrade Chair 5 to a high-speed quad and extend the Village Gondola at a later date. So the Chair 5 project that is listed in this thread is on hold.
#317
Posted 01 April 2007 - 05:36 PM
Whats the count now?
#318
Posted 01 April 2007 - 05:38 PM
Seven Springs - Pennsylvania
Replacing Chair 10 / Gunnar Slope CTEC Fixed-Grip Triple with a High-Speed 6-Pack for the 2007/2008 season.
No mention of mfg, but their existing 6-pack is a CTEC Garaventa, and they have been a loyal CTEC customer for years, which would assume that this lift will be a Doppelmayr CTEC lift.
#319
Posted 01 April 2007 - 06:47 PM
So Vail decided to go with L-P for the new detach. But are they using L-P for lift 14 replacement too?
