Von Roll Grips
Started by skierdude9450, Feb 22 2006 06:04 PM
5 replies to this topic
Posted 22 February 2006 - 06:41 PM
I believe that the wheel you see on the outside of the grip that looks like a support arm when the grip enters the terminal is actually the device that detaches the grip from the haul rope. I was looking at the detachble process when I was at Silver Mountain and those arms do go down and up about an inch, just enough for the clamp jaw to move outward.
Posted 27 February 2006 - 10:07 AM
Those grips work on the cam principle. Inside the spring pack, the rod is two parts which you obviously can't see. They look like the shocks on your car, but instead of the gas inside the shock providing the extension force, the spring pack does. Those arms with the small black rollers lift up on the whole rod where the spring pack rests, and that lifts the mobile jaw away from the rope. In the photo above, the fixed jaw is to the left or inside, and the mobile jaw is to the right or outside. The mobile jaw is hinged to the spring rod, and as the spring rod lifts up it pulls the moble jaw with it. These grips lock open because of the cam action of the spring rod/mobile jaw juction.
