Ryan, I presume those angles are right angles? I was just wondering because you have the end points circle and I'm just uses to seeing them with a 'box' where the two lines meet which indicates a right angle, thanks.
Random Lift Pictures Number Two
Started by liftmech, Jan 14 2004 07:59 AM
145 replies to this topic
#142
Posted 29 February 2004 - 03:32 PM
Small circle is the pivot point for the main axel for this style of assembly. The assembly has a flat spot in this area approximately the size of a 6 pack. 2 - 45's is pretty close. The most important aspect of the drawing is that if the hold down assembly has a pronounced movement the bullwheel alignment turns to cheese whiz!
Image shows 8 wheel hold down at portal and another hold down that is directly uphill. Uphill assembly is on a adjustable tower rather than floating.
Ryan B
Ryan B
#143
Posted 13 June 2005 - 05:33 PM
Bill, did you used to actually have pages for BC resorts with pictures? It would be so great if you got them up again! :D
#145
Posted 13 June 2005 - 06:39 PM
Great! I see what you mean. Dont you have a copy of the old site on your computer?
