Crescent Wrenches
18 replies to this topic
#1 Emax
Posted 31 December 2005 - 10:39 AM
We have overlooked the "powered" uses for the adjustable wrench!
Impact Wrench
[attachment=6850:attachment]
Rotary Hammer
[attachment=6851:attachment]
This post has been edited by Emax: 31 December 2005 - 10:40 AM
#2 Emax
Posted 31 December 2005 - 10:50 AM
Handy replacement fuse. Good for about 25,000 amps!
[attachment=6852:attachment]
#3 Emax
Posted 31 December 2005 - 07:13 PM
Also - if you have really strong thumbs - a "metric" wrench makes a dandy nutcracker!
[attachment=6853:attachment][attachment=6854:attachment]
No fake - it works!
#4 liftmech
Posted 02 January 2006 - 08:50 AM
Attachement attachment
How many amps is a 6" good for :devil:
#5 Emax
Posted 02 January 2006 - 09:18 AM
"How many amps is a 6" good for?"
I'm sure it will outperform the buswork in any swtich it'll fit into. Tried to get current ratings from Crescent and even Craftsman, but they've not gotten back to me.
This post has been edited by Emax: 02 January 2006 - 09:19 AM
#6 Allan
Posted 02 January 2006 - 09:51 AM
There's actually a log entry in our books from Blackcomb where someone used a cigarette foil package for a fuse replacement... ended up cooking all the lift HV controls.
#7 Lift Dinosaur
Posted 03 January 2006 - 08:13 AM
Attachement attachmentAttachement attachment
No fake - it works!
I might opt for the 16" Channel Locks for that application!
#8 ccslider
    ccslider
  • 186 Posts:
Posted 04 January 2006 - 07:03 AM
All this kind of goes along with the thinking that if the only tool that you have is a hammer, then everything looks like a nail.
#9 Emax
Posted 04 January 2006 - 08:55 AM
"if the only tool that you have is a hammer, then everything looks like a nail."
I really like that.
#10 Emax
Posted 04 January 2006 - 01:58 PM
Here's a "powered" application that's been overlooked!
Combination battery carrier / hand warmer.
Both needs that all ski areas have.
Quick and easy installation too.
[attachment=6873:attachment] [attachment=6874:attachment]
#11 Lift Dinosaur
Posted 04 January 2006 - 02:08 PM
Attachement attachment Attachement attachment
Only to be used with P.P.E.
#12 Emax
Posted 04 January 2006 - 02:29 PM
O.K. A couple of "un-powered" applications.
[attachment=6875:attachment] C.F.O. - style caliper
[attachment=6875:attachment] C.F.O. - style bathroom fixture
Blew that one.
[attachment=6878:attachment] the C.F.O. - style maintenance dept. caliper
[attachment=6879:attachment] the C.F.O. -approved maintenance dept. TP holder
This post has been edited by Emax: 04 January 2006 - 02:22 PM
#13 Emax
Posted 04 January 2006 - 02:44 PM
Dinosaur: "Only to be used with P.P.E."
[attachment=6880:attachment] ??
#14 Lift Dinosaur
Posted 05 January 2006 - 05:51 PM
Attachement attachment ??
New liftie on the 12 step program?
#15 wally
    Smoke test man.
  • 25 Posts:
  • Interests:Skiing, small ski areas, ski lifts. Technical stuff about lifts.<br />Retired electronic tech from Hill AFB (Electronic calibration).
Posted 20 January 2006 - 04:18 PM
:shocking:
I assume at least your guys who are electricians know how the the high tension crew with power companies used crescent wrenches.
#16 Lift Dinosaur
Posted 21 January 2006 - 04:39 AM
And for the rest of us?
#17 wally
    Smoke test man.
  • 25 Posts:
Posted 21 January 2006 - 07:42 AM
They used a untighten crescent wrench to see if a line was hot or not.
A crescent wrench was hung off the end of a series of hot sticks and raised up toward the tension line being tested. When the wrench got close to the line, the jaws and screw would start to make all kinds of noise.
This is caused by the magnetic field that surronds a hot line.
If the linemen did not have a certified set of hot sticks or a set he trusted, they would simply throw the crescent wrench up towards the line and listen.
This may explain why the linemen for the power companies
were the first to wear hard hats, next to steel workers : )
They no longer do this sort thing. One of the hot sticks has a electro-static voltmeter build into it that can
be easily read from the ground. I use to work for a calibration lab that calibrated those meters.
wally
#18 Emax
Posted 21 January 2006 - 08:31 AM
Great post Wally!
I feel another photo coming on...
#19 okemopoma
    Lift EMF
  • 176 Posts:
  • Interests:Tai Chi Chuan, Chi Gong, Kung Fu, Taoist Skiing.
    Oh yeah, and electrical stuff.
Posted 25 January 2006 - 06:56 AM
Ok, just when I thought I had seen it all!!!!!!
Far out!
At the top of the mountain, we are all Snow Leopards. - Dr. Hunter S. Thompson
