Rope selection
Posted 12 December 2005 - 02:32 PM
and has anyone seen or worked on a lift with fatzer's new jota rope?
Posted 12 December 2005 - 04:11 PM
Posted 12 December 2005 - 04:31 PM
Ski lift wire ropes in the U.S. are a very small percentage of the total volume that these companies do. You will notice that NONE of them have an office in North America.
Posted 12 December 2005 - 04:34 PM
Posted 12 December 2005 - 05:45 PM
Posted 12 December 2005 - 06:10 PM
P.S. I'm guessing that the third leg footrest had to be removed from the carriers since that didn't seem like a very good setup.
Posted 13 December 2005 - 09:03 AM
Allan, on Dec 12 2005, 08:39 PM, said:
Does WRI supply a solid poly core or a braided poly? What are your experiences regarding rope elongation after installation?
Thanks-
Posted 13 December 2005 - 11:46 AM
Posted 13 December 2005 - 04:40 PM
We installed the new Jota 42mm rope to all three of the Telluride Gondola sections two years ago.
This summer we went back to replace the smaller section with a new design (similiar to the original) (less profile on the plastic) due to plastic working its way out of the cable. Fatzer has worked out the bugs and I predict we will see more of it on the market soon. Telluride is the first and only "lift" with Joya installed to date. Other related Jota installs are at the Getty Museum in L.A. (28mm) and a people mover at a mid west airport. (28mm)
telluride saw a 70% decrease in sheave replacement and are able to have a conversation in the terminals now without shouting!
Splicing is straightforward with the addition of removing the plastic in the splice area then re-installing after the splice is completed. Fatzer created a special tool that relays the hourglass plastic inbetween the strands then the ends (at the tucks) are simply put into the core at the tucks.
Norm Duke is the recognized splicer in the U.S. for the Jota rope. Fatzer supplied a splicer from across the pond to help us the first time.
Posted 14 December 2005 - 06:12 AM
liftmech, on Dec 14 2005, 05:51 AM, said:
There are plastic pieces that fill the valleys between the strands that follow the lay of the rope, the result is a cross section is almost round versus a traditional cross section. The results are greatly reduced vibration.
Posted 14 January 2006 - 10:46 AM
#18
Posted 19 March 2006 - 05:44 AM
