Load Testing Discussion
Started by Kicking Horse, Oct 12 2005 08:40 PM
28 replies to this topic
#22
Posted 22 October 2005 - 07:43 AM
While at Bever Creek this summer I learnd that due to the 7 Year or mod requirment for load tests, BC had invested in a tractor trailor filled with trash bins which they use ( filled with water) to load the lifts. BC's lift department payed for the trailer and bins by renting them out to other resorts and still does.
#23
Posted 24 October 2005 - 05:37 AM
I heard that beaver creek also put corks installed from the inside of the garbage cans so all they have to do to drain them is hit the cork with a hammer as the lift is running to drain the buckets...much cleaner than the alternative way to drain them!
#24
Posted 24 October 2005 - 11:35 AM
We used to use the buckets with corks but had too many problems. Lots of leaks and broken buckets. We now use standard garbage bins and empty them by tipping them off. Just need the all rubber clothing.
#25
Posted 24 October 2005 - 04:32 PM
Oh so that's where all our buckets came from!!
#26
Posted 26 October 2005 - 05:44 PM
chuckm, on Oct 18 2005, 03:46 PM, said:
Hey guys, i was at the original silver bullet load test at the boat in 86, yes we did use beer (coors light) we did the load test and unloaded the lift that evening after a successful test. The coors people counted every single keg ! so unless they did it again with beer in the last 19 years- that info is not correct
Nice call CM. Its always good to have "on-site" info.Hope to see you again this winter.
#28
Posted 28 October 2005 - 09:21 AM
We use cardboard boxes with garbage bag's inside of them. We use a hole saw in the back of the box and when we are through just poke a hole in the bag and when the boxe's get back to the bottom they are empty. So far we have re-used the boxe's three times and will be doing two more load test's this fall.
