Model 3S ropeway
37 replies to this topic
#1 Zage
  • 358 Posts:
Posted 15 July 2005 - 05:49 PM
Welcome to the topic about my model 3S ropeway, I just started today with the terminals and will continue adding other components. Here is the drive terminal (just to note the tension terminal is the exact same as the drive station, only without the motor). The terminal is not fully loaded, it is missing the accelerator/decelerator tiers, cadence chain, extra support beams, detachable mechanism ect... it is just to show you the basic construction. As the days go on, more components will be added.
Tyler.M
#2 heavenly_romer
    HI
  • 316 Posts:
  • Interests:yo, my name is Christian, and I live in the San Francisco Bay Area (Berkeley ....sort of) skiing is what I do best, and I love the mountains. Of course I love skilifts too, which is why I'm here. I'd like to learn more about them and maybe work in the Ski industry later on in life.<br /><br />Let it snow.
Posted 15 July 2005 - 09:19 PM
very cool, looking forward to upcoming pics!
<!--coloro:red--><span style="color:red"><!--/coloro-->-Christian<!--colorc--></span><!--/colorc-->
<a href="http://www.myspace.com/the_skiing_beast" target="_blank">http://www.myspace.com/the_skiing_beast</a>
#3 Zage
  • 358 Posts:
Posted 16 July 2005 - 04:20 PM
Here is my fully loaded drive terminal. Just some info about the terminal, the accelerator tier bank is longer and goes faster that the decelerator tier bank to give the cabin plenty of time to properly attach and get up to line speed faster. Both tier banks are fully height adjustable. The cadence chain goes in a funny pattern because once again, the accelerator tiers start earlier.
Tyler.M
#4 Zage
  • 358 Posts:
Posted 16 July 2005 - 04:31 PM
Just to add, my model will be like the 3S system they have at Kitzbhule the way it goes down, then back up. Here is a video clip of the tier banks in action.
Tyler.M
#5 ODDfreakPERSON
  • 109 Posts:
Posted 16 July 2005 - 04:55 PM
Hahaha that is awesome! It's funny to see all the gears going so fast.
-Chris
#6 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 16 July 2005 - 06:31 PM
i agree, thats totally fabulous Zage! :biggrin:
This post has been edited by WBSKI: 16 July 2005 - 06:32 PM
#7 Duck
    Mechanical Designer
  • 391 Posts:
Posted 16 July 2005 - 07:46 PM
I'm following the geartrain, but the way you have it set up, it doesn't look like there is a different ratio between each tire, is that right?
(as in, all the tires rotate at the same speed)
-Iain
#8 Zage
  • 358 Posts:
Posted 16 July 2005 - 08:27 PM
That's right Duck, the accelerator tier bank have smaller gears and the decelerator tier bank have big gears, so the drive motor has a big gear and it drives the first accelerator shaft witch has a small gear and that will rotate faster than the drive shaft(basic science I'm teaching here :laugh: ) so the cycle is increase speed decrease speed. In the picture, the orange arrows are the accelerator tier bank and the blue arrows are the decelerator tier bank.
Tyler.M
#9 Duck
    Mechanical Designer
  • 391 Posts:
Posted 16 July 2005 - 08:43 PM
Unfortunatley, though, with your setup, while the acceleration tires are moving at a different speed than all your deceleration tires, all the tires on each "side" are going the same speed. You have to have a step-up or step-down per tire, to get each tire to rotate at a slightly different speed than the tire next to it. Check out how how it's usually done:
http://www.funivie.o...zbuhel_3s/3.htm
You can see how each tire has two pulleys on it. One is a different diameter - the ratio between each subsequent tire causes each one to rotate slightly faster (or slower).
-Iain
#10 Zage
  • 358 Posts:
Posted 17 July 2005 - 03:12 PM
My system works well, so I'm going to keep it that way. I performed a test to see if the tiers could accelerate the test cabin, now the test cabin weighs more then the actual cabin I will be using, but the tiers accelerated it with ease.
This post has been edited by Zage: 18 July 2005 - 08:08 AM
Tyler.M
#11 heavenly_romer
    HI
  • 316 Posts:
Posted 19 July 2005 - 09:27 PM
How's this project going? It looks great from all the pics so far, and I'm anxious to see it progress. :thumbup:
#12 Zage
  • 358 Posts:
Posted 22 July 2005 - 07:41 AM
Well here you go, these are the completed terminals. I will show you pics of the drive station first. The cool thing is that with my motor setup is that there is the main control box, 2 motors and it is all remote control. I could be 20 ft away and make the lift operate. Both terminals are missing the cadence because I'm lubbing them.
Drive station:
Attached File  100_0470.JPG (120.51K)
Number of downloads: 49Attached File  100_0481.JPG (96.16K)
Attached File  100_0482.JPG (104.11K)
Number of downloads: 24Attached File  100_0483.JPG (114.29K)
Attached File  100_0484.JPG (108.04K)
Pretend auxiliary engines:
Attached File  100_0471.JPG (78.96K)
Number of downloads: 29Attached File  100_0494.JPG (83.78K)
Drive motor:
Attached File  100_0472.JPG (91.96K)
Cadence chain motor:
Attached File  100_0474.JPG (76.91K)
Control box:
Attached File  100_0473.JPG (53.47K)
Tyler.M
#13 Zage
  • 358 Posts:
Posted 22 July 2005 - 07:46 AM
Tension station:
Attached File  100_0487.JPG (107.67K)
Number of downloads: 35Attached File  100_0488.JPG (91.67K)
Attached File  100_0492.JPG (93.32K)
Tension lorry:
Attached File  100_0491.JPG (79.13K)
Number of downloads: 26Attached File  100_0485.JPG (84.13K)
Motor controls:
Attached File  100_0486.JPG (67.7K)
Tier bank:
Attached File  100_0493.JPG (45.79K)
Tiers:
Attached File  100_0490.JPG (62.59K)
Tyler.M
#14 Zage
  • 358 Posts:
Posted 22 July 2005 - 07:54 AM
Here are some other things, including a video of a cabin accelerating.
Test cabin:
Attached File  100_0468.JPG (82.75K)
Weight cabin:
Attached File  100_0469.JPG (73.65K)
Pretend exhaust and air intake for engines:
Attached File  100_0495.JPG (87.74K)
Here is my detachable grip :laugh: :
Attached File  100_0477.JPG (51.37K)
Here is the clip:
Attached File  100_0501.MOV (1.55MB)
Tyler.M
#15 Zage
  • 358 Posts:
Posted 22 July 2005 - 06:43 PM
The terminals are all installed and I'm going out tomorrow to by some cable for the haul and track ropes.
Tyler.M
#16 Zage
  • 358 Posts:
Posted 28 July 2005 - 08:21 AM
Here are some data of my tri-cable system.
1.Vertical rise(floor to bottom of station):2 feet 9 inches
2.Length(back of station to back of station): 16 feet 4 inches
3.Tower(s):1
4.Tower length(bottom to top): 2 feet 9 inches
5.Cabins: 2-3
[/U]Drive station info
1.Drive motor: K'nex hi-torque
2.Cadence motor: K'nex hi-torque
3.Tier bank motor: K'nex hi/lo speed
[U]Tension station info
1.Counter weights: hockey pucks
2.Tier bank motors: 3 K'nex basic
3.Cadence motor: 1 K'nex basic
Haul rope: white nylon
Track ropes: wire rope
Total build days: 15
This post has been edited by Zage: 04 August 2005 - 11:53 AM
Tyler.M
#17 Zage
  • 358 Posts:
Posted 04 August 2005 - 11:55 AM
There were some complications with the haul rope, apparently it was to big and bulky and could not be deflected very well. So I'm going to buy a smaller haul rope.
Tyler.M
#18 Zage
  • 358 Posts:
Posted 05 August 2005 - 05:07 PM
Here are pics of my project.
The tower:
Attached File  100_0617.JPG (58.91K)
Number of downloads: 50Attached File  100_0618.JPG (74.53K)
Attached File  100_0619.JPG (61.03K)
Number of downloads: 39Attached File  100_0620.JPG (63.61K)
Line:
Attached File  100_0622.JPG (64.25K)
Number of downloads: 22Attached File  100_0630.JPG (79.36K)
Attached File  100_0644.JPG (85.03K)
Number of downloads: 29Attached File  100_0648.JPG (67.62K)
Rope set-up:
Attached File  100_0631.JPG (105.6K)
Number of downloads: 27Attached File  100_0639.JPG (93.67K)
Attached File  100_0632.JPG (61K)
Drive station:
Attached File  100_0621.JPG (104.57K)
Number of downloads: 35Attached File  100_0623.JPG (132.56K)
Attached File  100_0637.JPG (59.5K)
Tension station:
Attached File  100_0626.JPG (93.35K)
Parking rail:
Attached File  100_0624.JPG (87.42K)
Number of downloads: 38Attached File  100_0625.JPG (86.34K)
This post has been edited by Zage: 05 August 2005 - 05:14 PM
Tyler.M
#19 Zage
  • 358 Posts:
Posted 05 August 2005 - 05:10 PM
Here is a temporary material ropeway for the tower:
Attached File  100_0655.JPG (87.04K)
Number of downloads: 49Attached File  100_0656.JPG (84.52K)
Attached File  100_0658.JPG (75.74K)
Number of downloads: 31Attached File  100_0659.JPG (96.68K)
This post has been edited by Zage: 05 August 2005 - 05:12 PM
Tyler.M
#20 Ram-Brand
  • 11 Posts:
Posted 06 August 2005 - 12:46 AM
Nice work and great video. :biggrin:
Webmaster: Lift-World.info
