Hanging a chair in my front yard
11 replies to this topic
#1 paxman
  • 3 Posts:
Posted 15 June 2005 - 06:57 PM
Recently I came into a double chair from Copper Mtn, one of their originals circa 1969. Any thoughts on how to hang it so it swings primarily front to back and side-to-side? Thanks
#2 edmontonguy
Posted 15 June 2005 - 07:15 PM
Use a double mounted joint. Use the original grip mount hole to insert an axel with bearings for added smoothness. Mount the grip axel parrallell with the seat back. That covers front/back motion. Side to side is a little more complicated but essentially involves the ends of the axel being mounted to another beam which hooks into a pivot running perpendicular to the seat back. This might be a little bulky in design though.
#3 paxman
  • 3 Posts:
Posted 15 June 2005 - 07:30 PM
Thanks. Is there a way to fabricate the axle/bearings for the grip mount without breaking the bank?
#4 edmontonguy
Posted 15 June 2005 - 07:35 PM
Try a local scrap metal dealer. They usually sell cheap by the pound metal and you can usually find decent sized bars. Plate steel is also available at places like this. Bearings are optional and would soley be for added comfort and less noise.
#5 poloxskier
Posted 15 June 2005 - 08:48 PM
Just out of curiosity do you know which lift it came from?
#6 Jonni
    Dreams drive the world.
  • 849 Posts:
Posted 16 June 2005 - 03:26 AM
I wonder if using an old universal joint from a four-wheel drive car or truck would work. You could probably get something like this at a junkyard.
#7 Aussierob
Posted 16 June 2005 - 04:17 AM
The uni joint might do it, keep in mind it not designed to be loaded in that direction. You could try just hanging it from a piece of chain. It will go everywhere no problem. I'm hanging an old double chair from Magic next weekend. It's going to be a simple swing though.
#8 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 16 June 2005 - 07:53 AM
How many old double chairs do you have up at Whistler-Blackcomb that arent on a line? Ive seen one hanging outside of rendevous.
#9 Aussierob
Posted 16 June 2005 - 08:35 PM
A lot. We have way more triples lying around but they're not giving them away just yet.
#10 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 17 June 2005 - 05:53 AM
Cool! if you start selling them off i might be interested in buying one.
#11 paxman
  • 3 Posts:
Posted 20 June 2005 - 07:22 PM
It is a YAN chair, off the old B1 lift from Copper Mtn, CO
#12 Lift Dinosaur
Posted 08 August 2005 - 01:57 PM
That would be circa 1973 as B-1 and I were installed in 1973.
