Kicking Horse, on Jun 1 2005, 09:20 PM, said:
they had 2 other ropeways there @ one point from what i understand. Now there is only the one.
I know they used to have a 2nd gondola that ran from midway near the terminal near iron dragon and would drop you off on the upper level of the bathroom facility located next to the mine ride. You used to be able to see the gondola cabins in the boneyard before the area was cleaned up for the new campground.
The only other aerial lift that I am aware of was a monorail that they had that used to occupy the space near the blue streak.
Duck, on Jun 2 2005, 05:51 AM, said:
When you're there, stand next to the hydraulic building (across from the washrooms beside Magnum's entrance). Watch the deflection sheaves that lead the rope down into the winding drum. And then let someone tell you that gondolas or chairlifts can't run faster than a certain speed because of sheave wear or whatever.
-Iain
yeah, I love standing back there, especially when you can feel the ground shake from the launch. Top thrill dragster has become quite the headache for the mechanics there, a lot more than originally anticipated. Between cables breaking, problems with the hydraulic motor during the first season, and rolbacks, one has to wonder if Cedar Point would have installed the ride if they knew what expenses were going to be incurred.
I was at the park on Friday for coastermania and had a great time. had to escape during the day a bit as it got crowded w/ all of the school groups but after 6 most of the rides were less than 15 minutes to get on.
