pics of SUmmit Express lift at Winter Park?
13 replies to this topic
#1 bramat
  • 27 Posts:
Posted 20 May 2005 - 08:41 PM
does anyone have pics of the Summit Express lift? or, does anyone know the brand name, the stats, the dependability, etc?
im very excited about Mission Ridge, WA getting this lift, and want to discuss.
brandon
seattle
#2 SkiBachelor
Posted 20 May 2005 - 08:48 PM
Here you go:
http://skilifts.org/co-winterpark.htm
#3 liftmech
Posted 21 May 2005 - 05:33 AM
Here are a couple of pictures of the drive end. I assume Mission is going to reverse the orientation and place the drive at the bottom, like the current chair 2. Summit is basically the same lift as Rex at Crystal; it's three years older and may look different on the outside but the running gear is the same. While it's always sad to see another classic lift go down, I think Mission could definitely use a detachable where chair 2 is. Long ride.
#4 ZackyJeff
    Z-Man
  • 45 Posts:
  • Interests:Sports, Computers, Games.
Posted 24 May 2005 - 11:12 AM
Looks like a 2-in one station (a detatch and fixed chair station all in one).
Officially Posted By ZackyJeff
- PC Platform Games Reporter -
Part of the SkiGaming.com Team
http://img103.exs.cx...6/12-13-002.png
My New Site: www.zacksskisite.zoomshare.com
#5 floridaskier
Posted 24 May 2005 - 12:53 PM
That's basically what it was...Poma's first detachables consisted of the Alpha drive terminal used for fixed grips and another separate building for the detachable equipment. They also made a vault-drive version (American Flyer at Copper Mountain and Colorado at Breckenridge, others?). The return terminals were the same, minus the Alpha drive setup
#6 SkiBachelor
Posted 24 May 2005 - 01:49 PM
ZackyJeff, isn't the HSQ at Hunter Mountain set up the same way?
#7 Bill
    Founder
  • 2,851 Posts:
Posted 24 May 2005 - 02:19 PM
This is going to be a fun lift to have in one of my backyards. Hope to have first hand pics someday soon from its new home at Mission Ridge.
#8 NoPainNoJane
  • 169 Posts:
Posted 26 May 2005 - 05:39 AM
I stopped by Mary Jane yesterday afternoon to check on the progress of the Summit Express removal, and it seems to be done. No sign of chairs and the load terminal was gone and already graded. Lift towers were still standing, but the cross arms and sheaves had been removed. Leads me to believe that the towers are going to be re-used. They've also started removing trees adjacent to the existing lift line as the new lift will need a wider line than before.
I will try and upload pictures tonight when I get home, just have to figure how to shrink them.
#9 liftmech
Posted 26 May 2005 - 05:51 AM
According to some of your fellow monkeys I met at RMLA, the tower tubes will be reused with the sixpack caps on them.
#10 highspeedquad
    Fixed grip hater, L-P lover.
  • 764 Posts:
Posted 26 May 2005 - 01:45 PM
Will they have to reinforce them to accomodate the extra weight?
#11 ZackyJeff
    Z-Man
  • 45 Posts:
Posted 26 May 2005 - 03:03 PM
Well, kinda.
Snowlite Express Summit Station:
Summit Station
Snowlite Express Base Station:
Snowlite Express
Snowlite Express
C Lift Top Station (Alpha Station)
C Lift Top Station
C Lift Top Station
#12 liftmech
Posted 27 May 2005 - 07:40 PM
Shouldn't, if the original foundations are still sound. It's the same steel regardless of whether it's a double or a sixpack. We put a quad on old double towers when we rebuilt Baker's C-2.
#13 coskibum
  • 596 Posts:
Posted 28 May 2005 - 06:38 AM
here are some shots of the old chair:
base:
line:
summit:
i also read that they are going to keep the towers and reuse them for the new lift. most of the time, towers are designed with such high safety factors that they can support the loads from greater chairs.
this is the cinch express at beaver creek (CTEC-Garaventa). it uses old doppelmayr towers from the pre-existing triple chair that was there.
#14 vons
Posted 28 May 2005 - 06:10 PM
No reinforcement is needed for the towers. Beaver Creek has up graded two triples to HSQ Strawberry park and Cinch I have not found out yet if the larkspur bowl lift will reuse the old tubes or if the line location has changed and thus new everything will know on the 14th. Tubes are the same for most lifts now crossarms are an other story because one you need a wider gage and two the forces act on the beam in bending which most materials, including steel, are not as efficient.
