Auxiliary drives
Posted 27 April 2005 - 02:27 PM
Posted 27 April 2005 - 03:29 PM
The colorado code also requires at lease two power sources for lifts that are off the ground. The second power source can be a small engine that runs slower to just evac the people or it can be a large diesel that can run all day at full speed. The code also requires to run the diesel motors and do some tests every few days.
This post has been edited by Mike: 27 April 2005 - 03:32 PM
Posted 27 April 2005 - 04:08 PM
Mike, on Apr 27 2005, 06:29 PM, said:
"Slower" is definitely the operative word. Years ago (early 70s?), I was skiing at Pico (VT) and was on the Lower Chair maybe within 10 chairs of the load when the power went out. After a few minutes, we were on our way at a painful crawl as they ran the diesel to evacuate it. 30 or so minutes and now probably no more than 10 chairs from the top, we stopped. A couple of minutes later, we were on our way at full speed as the power was back.
That wasn't my only power failure story there. Another time, I was on their Summit Chair less than two chairs from the top when the power went out. I don't think this lift had a backup engine. Fortunately, I was close enough to the ground that when they decided to evacuate, all it took was dropping the skis and having the lift operator grab my legs and have me make a controlled jump. Everyone else had to wait for the patrol to do it with ropes. Better yet, back then they had a Poma extremely steep surface lift that was only diesel powered and just served the upper mountain (from about the same elevation as the Summit Chair's mid-unloading station). So for the next hour or so, it was the private lift of those of us lucky enough to be caught on the upper mountain and brave enough to ride the thing.
Posted 27 April 2005 - 08:16 PM
Posted 28 April 2005 - 04:59 AM
Posted 28 April 2005 - 05:28 AM
liftmech, on Apr 28 2005, 05:59 AM, said:
Do your operators actually hoook the diesel up and run it? Only maintenance guys do it here. Lifty's just stand at the unload like normal.
Posted 28 April 2005 - 03:39 PM
Posted 30 April 2005 - 01:36 PM
The last time it was in the March break (!), when the South Laurentians (from Laval to St-Sauveur) lost power. I just arrived in the waiting line for my first run when the three lifts stopped at the same time. After 15 minutes (!) they finally started the auxiliary for evacuating. I began hiking the mountain and I was going faster than the chairlift.
They just ran one lift at a time so it took one hour to evacuate the two chairlifts (the third one is a surface lift).
When we finally got power they had a problem with one of the two chairlift so the waiting line was..... very long.
They finally managed to run the second chairlift one hour later. (The time it took to go get the missing part at the Doppelmayr plant and installing it on the chairlift, the plant is just twenty minutes of road from Mont-Habitant)
Posted 07 May 2005 - 04:43 AM
Posted 07 May 2005 - 11:16 AM
Allan, on May 7 2005, 06:31 PM, said:
In Norway we have to start the motor once a week and running the lift on it once a month (30 days of use). Our gondola uses a diesel and our chairlift a mean ford V8 gas engine. We also have to submit oil samples on regular basis to a lab to look for engine wear.
"We are the people our parents warned us about." Jimmy Buffett
#20
Posted 19 May 2005 - 06:37 PM
As for interesting aux motors, we have a 1963 Mueller double that uses a 12hp Wisconsin Engine. That little bugger starts on the coldest of mornings and has never needed more than an oil change and new spark plugs.
