Question about Whistler Village gondola..
Posted 14 March 2005 - 10:37 AM
In the mid-station, on the upload side, there is a control booth. On the back wall of this booth is a long display which graphically shows the layout of the whole gondola, with the stations and towers and such. Each cabin is represented by a green LED, and you can see the display update every few seconds as the system is running. Now, there are always a few LEDs which are blinking .. and my question is: what do the blinking LEDs indicate?
I'm pretty sure that the blinking LEDs do not signify a gap (ie: missing cabin), as that is done simply by not lighting the LED in the first place. They don't seem indicate empty (or full) cabins, as only maybe 2 - 5 seemed to be blinking each time I went through.
Any ideas?
Thanks,
Cameron.
(No, I'm not the same Cameron who knows everything about ski-lifts!)
Posted 14 March 2005 - 11:01 AM
The blinking cabin LED's are cabins that are "marked" by the lift operators. When they arrive at the next station a signal goes off. It's used for cabins that have "stuff" in them instead of people. It would be better if you could mark a cabin all the way to the other end of the lift. Right now it only marks to the next station and the lifty there has to mark it again for the next section. You may have noticed 2 large (4 cabin) gaps. They are shipping spaces for food/arbage/ambulance car etc..
Posted 14 March 2005 - 03:13 PM
Posted 14 March 2005 - 04:31 PM
Posted 14 March 2005 - 05:18 PM
On some lifts, there's a button on the controls that says 'Mark.' Is that related to the display in the Whistler gondola in any way?
Posted 15 March 2005 - 05:54 AM
Posted 15 March 2005 - 08:41 AM
Posted 18 March 2005 - 04:30 AM
And then that's used to measure the distance of the haul rope and roughly indicate when that cabin is aproaching the next terminal, then using a prox switch there to verify it's arrived?
-Iain
Posted 18 March 2005 - 11:44 AM
-Iain
I think it would just count carriers. That is, it knows there are, let's say, 50 carriers on the uphill side, so the 51st carrier to enter the upper terminal is the marked one.
Posted 19 March 2005 - 07:05 AM
Kicking Horse, on Mar 18 2005, 12:11 AM, said:
Not yet- haven't gone to work in a while- read my blog since it's way off topic here.
Posted 19 March 2005 - 07:12 AM
pete643, on Mar 18 2005, 12:44 PM, said:
Denpending upon the age of the lift, sometimes it simply marks a spot on the rope and then, half the line later, sounds an alarm at the oposite terminal. Newer Pomas have a marker on chair 1, so that the system can space things properly. The system then just counts carriers as you mentioned. I'm not sure how the older retrofits work, that's why I wanted to know which prox switch Rob's gondola used (my lift is a year older and has more or less the same systems). Since my computer knows how many feet it takes to stop, I'm assuming it also knows approximately how long the line is and can mark acarrier's position on the rope. 9800 feet later, it signals the opposite terminal. I really don't know but that's my supposition.
Posted 19 March 2005 - 10:29 AM
#18
Posted 19 March 2005 - 02:31 PM
#19
Posted 20 March 2005 - 09:33 AM
The CIS system is calibrated from the outgoing #11 AC prox. to the incoming #1 AC prox. at the opposite end. These are counted in impulses ( I think long impulses ) from the impulse sheave at the station the carrier is coming to. A percentage of these impulses are knocked off the total to get the red CIS bell to go off before the marked carrier reaches the station.
