HSQ vs. FGQ Capacities
Posted 13 March 2005 - 02:50 PM
I got to thinking about these two lifts and came to realize that FGQ often have a higher true capacity that HSQ. It seems to me that the uphill capacity per hour is not the best capacity metric. I'm not aware of a better one but what is missing from the uphill capacity per hour metric are the effects of the speed of uphill transportation and the number of people on the chairlift at one time.
To illustrate my point, consider the following example:
-Consider two ski areas each with just one lift and similar terrain.
-One has a HSQ and one a FGQ both with uphill capacities of 2400 skiers per hour. (They would also have the same time between chairs loading and unloading)
-Both lifts are the same length.
-The HSQ has twice the line speed of the FGQ.
-Lets say the FGQ has 100 chairs.
-Given this information we can infer that the HSQ would have approximately half the number of chairs (50)
Now lets try to determine the total capacity of the two ski areas. The total capacity is simply the number of skiers on the runs and the number on the lifts. Because the two ski areas have the same terrain and same time between unloading, the number of people on the runs would be the same. Lets say 100 people. The number of people on the FGQ would be 200 (100 chairs / 2 *4 people per chair) The number of people on the HSQ would be 100.
So the ski area with the FGQ would actually support 100 extra people (50% greater capacity resort capacity). Furthermore the FGQ would have a 100% greater lift capacity. This result leads to an counter intuitive situation: If a resort replaces a FGQ that has no line, but is near capacity with a HSQ, the new lift would actually have a significant line. (100 people in the example above)
I realize that the metrics above are easily derived from the standard metrics you see on a ski lift, but is there a single metric I am unaware of that depicts this difference in lifts? Any thoughts?
NOTE: I realize that I have made some assumptions in my figures above, but I think they are realistic assumptions.
Posted 13 March 2005 - 03:12 PM
Posted 13 March 2005 - 08:21 PM
Those 100 extra riders have to go someplace and in the strict mathematical sense they go to the bottom to stand in line. This point is rarely pointed out in lift manufactures marketing brochures with the exception being Riblet.
In reality, tests done at Agony Acres and other areas have proven that the riders are absorbed into the ski runs. This seems to create a higher density run that slows the skier and therefore increases his total round trip time, so there is no apparent wait in line that nathanvg predicts. Unless it's in the early morning or at the end of the ski day.
Other odd but significant factors for slope density are HSQ riders endurance throughout the day and seasonally too.
If highspeedquad says a HSQ's speed can be increased that’s true but it makes the comparison invalid because FGQ's top line speed is … well fixed.
Other arguments for either side comparison are actual loading capacity vs. marketing brochure capacity.
For more info use skilift org's search – capacity, loading, and Riblet.com.
Ryan B
Posted 13 March 2005 - 09:43 PM
e.g.
whistler
moderate day = 20,000 skiers
12 HSQ's say an average of 250 people on uphill side
8000 acres
12 x FGQ's would have 500 ppl on the uphill side, so 3000 less on the hill at any one time. Not a huge difference in 8000 acres (14,000 vs 17,000). Most people prefer the shorter ride time and greater amount of skiing.
note: numbers used are VERY approximate. :)
Posted 14 March 2005 - 10:39 AM
Ryan B
You make some good points Ryan, but I don't quite understand your point on the difference in run density between the FGQ and HSQ. Since both lifts unload the same number of skiers per a given time, it seems that they would have nearly identical density of skiers on a run. Thanks for your thoughts.
Posted 14 March 2005 - 10:58 AM
Aussierob, on Mar 14 2005, 12:43 AM, said:
e.g.
whistler
8000 acres
I agree that my numbers are small, but they should scale up linearly. Your numbers above seem to make the point that there are more skiers not on the lift than my numbers indicate. This may be true. Assuming that 20,000 skiers and 12 quad lifts is accurate for whistler there are many skier unaccounted for as you point out. There are several other factors that may play a significant role in your more complex example above. Some of these factors include: skiers not skiing the whole day, waiting in lifts lines and skiers taking lunch and rest breaks.
You number of 3000 skiers on all HSQ lift at a given time would indicate that only 15% of skiers or 15% of a skier's day is spent on a lift? If a HSQ lift ride time averaged 6 min. and you skied an 6 hour day (with no breaks), you would only ride 9 lifts in a day. Furthermore your average run would be 40 min long. I don't think this is accurate.
Your scenario is obviously more complex and as a result any statistics about it will have more error. I agree that as a skier a HSQ is more desirable than a FGQ. I just wanted to spark a little discussion on the issue.
Posted 14 March 2005 - 03:10 PM
Posted 16 March 2005 - 04:48 PM
Aussierob, on Mar 15 2005, 12:01 AM, said:
I rethought my number and I do think there is a slight error. The basic idea is that a skiier is on the lift 15% of the time and on a run the other 85%. Given a lift ride to be 6 min. Here is my math:
6min_____/15_______*85_______= 34 min
lift_____convert_____multiply_________run
time____to 1%______to get 85%______time
What I got before was lift time(6) + ski time(34) = 40 min
This post has been edited by nathanvg: 16 March 2005 - 04:50 PM
Posted 16 March 2005 - 05:21 PM
University Of Colorado at Boulder
Posted 17 March 2005 - 12:38 PM
If u have a short lift say 500ft and it could carry 2400pph. Once a passenger reached the top it may take them about 3 min to get back down and ride the lift again. So you would have the same person riding the lift every 3 min.
With a longer lift about 4500ft it may take a person 30 min to ski down therefore the lift can serve a greater number of people because the same person would be riding the lift every 30 min. The longer lift would also have 9 times the number of chairs.
If you had a large resort with very short lifts then you would need a much greater capacity compared to a resort with long lifts.
This post has been edited by skiPhreak: 17 March 2005 - 12:42 PM
Posted 19 March 2005 - 07:25 AM
I think people are digging too deep on this one. Lift capacity really is pretty simple. Every six seconds, excepting lifts that stop a lot, two, three, four, or six people get off the lift. That won't change if the lift is 100' long or 10,000'. If a lift has a 2400 PPH capacity, then every hour under normal operating conditions 2400 people will ride the lift. It's that simple. A better measure of what most of this thread is attempting to discuss is Comfortable Carrying Capacity, or CCC. This is a measure of how many people the hill can support, based upon run acreage, skier ability, and general mountain conditions. A lift that pumps out more people than a designated area's CCC has too much capacity. One that dumps out half of the CCC coupld be upgraded. This does not take into account the wait in line; I don't know that you can really account for that anyway as lines fluctuate on a minute-by-minute basis.
Posted 19 March 2005 - 02:28 PM
Posted 19 March 2005 - 02:37 PM
Posted 19 March 2005 - 09:37 PM
#18
Posted 27 March 2005 - 11:12 AM
SkiBachelor, on Mar 20 2005, 01:44 AM, said:
18% is an interesting statistic. I wonder what the conditions of the test that generated this stat are? The whole FGQ vs HSQ capacity question is largely dependent on the type of terrain. It is particularly evident at Midwest ski areas. This is because Midwest ski runs are typically directly under or next to the lift. The result is that the ski run is the same length as the lift but skier ski much faster than ski lifts. The result is that the number of people on a lift at a given time is the largest factor in ski area capacity. As you consider longer run length to lift length ratios the effect is reduced.
#19
Posted 28 March 2005 - 05:03 PM
